Perhaps the pump in the water cooler is huge and inefficient, and taking 500W. Ever thought of that?Only a power meter to measure drawn power from the PC. The drawn power is = to dissipated heat.
Ahh, then I would advice to get a frequency converter installed in combination with a PLC and a PT100 transmitter. A simple case of energy optimization.Perhaps the pump in the water cooler is huge and inefficient, and taking 500W. Ever thought of that?
100W? More like 550...My point was that it heats up the room just as much as if it was air cooled. What kind of room is that, that can be heated by a ~100 W average dissipating electronics, a closet?
One needs to measure the average usage to know - my Precision laptop (with GPU) it on the order of 90 watts full tilt. Desktop more like 450 full tilt.100W? More like 550...
A GPU at full swing is quite power hungry.
I still can't get past the extraneous comma in the threat title.
If it is able to boost higher because of the chip being colder than when air cooled, yes. Most new GPU's are power limited rather than temperature limited though. Meaning the boost limit will be dictated by the power consumption limit in the vBIOS before reaching the temperature limit. At least when talking about desktop video cards.If the GPU/CPU is able to draw more power because it is being cooled more effectively, you will have more heat to dissipate, right?
Dissipated heat will still be equal to what power is being consumed.
Great. That's not always the case.Both my CPU and GPU clocked higher with improved cooling.
Yebbut by the time you've added that kit you're up at 800WAhh, then I would advice to get a frequency converter installed in combination with a PLC and a PT100 transmitter. A simple case of energy optimization.
Nah, VLT's are usually 90-98 % efficient. It could work. If one had absolutely nothing else to spend their time and money on.Yebbut by the time you've added that kit you're up at 800W
Just like class D Amps, only when running at or near full power - and for the higher end of that range only on seriously high power drives.VLT's are usually 90-98 % efficient.
Just glad I am not a gamer anymore.
Along with Bitcoin mining, it sure seems like a power hungry pastime.
I will stick to occasional use of my 140W valve amp!
Little buggers get under your skin don't they. One of the toughest things I ever had to do was take our little man to the vets to end his pain. Just writing that and I'm welling up, 4 years on.Still miss my wee pal
I do. It isn't.Don't know if class D reliablility is still an issiue.
I water-cooled a 7900 XTX and a Ryzen 7 for a reason...One needs to measure the average usage to know - my Precision laptop (with GPU) it on the order of 90 watts full tilt. Desktop more like 450 full tilt.
Actual “area under the curve” usage is very noisy though WRT power draw. One really has to measure (buy a Kill-a-Watt).
Can attest to gaming towers making a difference - we have 2 in a corner office (approx 13 ft per wall aka 16 meters squared) and with both running, and 2 humans using them, the room gets noticeably warmer with the door shut.
FYI - the humans are a non-trivial load: https://www.engineeringtoolbox.com/persons-heat-gain-d_242.html
