When you really want to find out the differences between DACs level matching is important within 1% (0.1dB).
And this I am doing in CoolEdit Pro, and not by a Bastlerei method . However, no ABX difference between two at least average DACs.
Will you suggest a null method then
Haven't tried headphones I'd think it works even better over phones.
Get a cable like this one. Male on both ends. Plug it in place of your headphones. Many people have one to connect telephone to car stereos.
You can use the other end to check voltage output with a multimeter. It can be a bit fiddly, but not terribly so. Put the black lead on the sleeve or ground portion. Put the red lead on one of the other parts of the plug to check either right or left channel. If you have balanced headphone outs, then this will be different.
Find a comfortable volume for your test with one of your DACs. Without changing volume send it a test tone, 1 khz is fine, 440 hz might be better for a cheap multimeter. I'd suggest a -6 db tone. Write down the voltage. Switch to your other DAC, and sending it the same test tone, adjust volume on it to match the voltage reading with your first DAC. Get the two within 1% of each other. If you read 1.oo volts then you want something between .99 and 1.01 volts. Takes longer to read these instructions than to do it once you have done it a couple times.
Now as long as you don't change volume on either DAC you can switch back and forth with matched volumes. If you have a headphone amp you can even change volume on it as long as the DACs are putting out the same voltage/volume.
With the Pentaconn connector, to measure the left channel the black lead of the MM connects to L- and the red lead to L+. Similarly, for the right channel, black lead to R- and red lead to R+.Ok, for balanced measurement, suppose I connect the amp as such:
So, measurement of the the voltage using DMM, would be black lead to "G" and the red lead to ?. Thank you in advanced.
Yes this. You are measuring the difference between plus and minus. You don't use ground for these purposes.With the Pentaconn connector, to measure the left channel the black lead of the MM connects to L- and the red lead to L+. Similarly, for the right channel, black lead to R- and red lead to R+.
I was also a bit surprised to perceive beating on headphones with pure tones in each ear.Speakers will produce the beating in the air.
Headphones would be interesting, with the different signal in each earpiece, since there is no beating, except that which your brain creates.
You might try that condition right away.
I was surprised (somewhat) to hear beating where none physically existed, one pure tone in each ear.
I think @j_j explained it all to me, but I can't find the posts right now.
Okay so this has turned into a cautionary tale. I thought I could hear the beat frequency change volume when on channel was reduced in level by only .1 db which was surprising. Of course I was looking at the sound editor and knew where I had made the changes. Don't under-estimate your eyes ability to confound your ears.
I found when I covered the screen and listened the difference disappeared. Once gain sighted listening strikes. I can hear a difference, but only when on channel is reduced about 1 db which is not surprising.
Mea Culpa!
I suppose in this case, it is ok just to pick either L or R, for the measurement ie be consistent for each setup, right?With the Pentaconn connector, to measure the left channel the black lead of the MM connects to L- and the red lead to L+. Similarly, for the right channel, black lead to R- and red lead to R+.
Yes, pick either and be consistent between the DACs, i.e. pick just the L for both DACs or just the R for both DACs to match the voltages to within +/- 1%. Please see Post #26 and Post #58. Same thing even if you use unbalanced (single-ended) 3.5mm connectors: pick a single channel, either L or R, consistently for both DACs, to match the voltage.I suppose in this case, it is ok just to pick either L or R, for the measurement ie be consistent for each setup, right?
Perhaps you (and other Adobe Audition users) can try oldsCool mentioned in this post:CoolEdit Pro
My DMM has already arrived. Is it ok if I use this cable to attach to DAC and do AC voltage measurements ?Get a cable like this one. Male on both ends. Plug it in place of your headphones. Many people have one to connect telephone to car stereos.
