Dear All
Good Day
I recently listened to the Elac Debut DF62 and the sound was close to my requirements (blues,rock ,metal). Since i'm considering to buy a pair of these, i would like your technical advice whether my amplifier is sufficient to drive the specific speakers without a problem or if i should proceed with a more solid one.If so , what amplifier would you suggest ?
I own the Yamaha RN803 D with the below specs :
High Dynamic Power/Channel (8/6/4/2 ohms) 140 / 170 / 220 / 290 W
Minimum RMS Output Power 100 W + 100 W (8 ohms, 20 Hz-20 kHz, 0.019% THD)
Elac Specs:
Speaker type: 3-way, bass reflex
Tweeter: 1 x 1-inch cloth dome
Midrange: 1 x 6.5-inch woven aramid-fiber cone
Woofer: 2 x 6.5-inch woven aramid-fiber cone
Crossover frequency: 100 / 3,000 Hz
Frequency response: 39 to 20,000 Hz
Sensitivity: 87 dB at 2.83 v/1m
Recommended amplifier power: 30 to 150 wpc
Nominal/peak power handling: 80 / 150 wpc
Nominal impedance: 6 Ω; minimum 5.4 Ω
Binding posts: 5-way metal
Magnetic shielding: No
Cabinet finishes: Black brushed vinyl
Accessories included: Removable fabric grille
Height: 43.0 in / 1,092 mm
Width: 8.5 in / 216 mm
Depth: 10.0 in / 254 mm
Net weight (each): 46.7 lb / 21.2 kg
Thank you in advance
Good Day
Elac Specs:
