upgrading fosi bt20a power supply
Yaniv
hi
i have fosi BT20A bluetooth amp, and loving it. it come with 24V 4.5A power adapter.
i see on amazon i can buy the "fosi 48V 5A power adapter supply", which is used for fosi BT20A *PRO* .
can i use it for my amp, or will it burn my amp? do i gain better sound quality? i listen mostly in low to moderate volume.
thanks
fpitas
Northern Virginia, USA
Unless the manufacturer says it's OK, I'd be real careful. Besides part voltage ratings you might overheat things. If you listen at moderate volumes, I doubt you will gain much quality, either.
Kimbrough Xu
hi
thanks
No, it is 12-24V for BT20A.
aon500
Better sound quality for your system? idk :p:p
But you will get more dense and rich sound.
