I haven't read all 33 pages of comments, rather just a few comments, so I'll just comment a bit on the original question: Can you mention some neutral phono cartridges?
I have plenty of measurements of non-neutral phono cartridges that I can share, since most phono cartridges are not neutral, and I would even claim that the majority of vinylphiles aim specifically for cartridges that are not neutral - they
want vinyl to sound different than digital, so therefore they choose a cartridge with a specific flavour that they like - after having tried cartridges that were either too "harsh" or too "dull" sounding or whatever.
Anyway, besides finding measurements online, what I've done with cartridges I've had in my possession has been to record a song from a record that I know to have been cut flat from the CD master and then compare the CD-rip with the recording of the vinyl record with the plugin Voxengo CurveEQ, which shows the difference in EQ between the two, which means it draws a line, which will be the frequency response of the cartridge.
The records I've used for this are:
* Type O Negative "October Rust"
* Living Colour "Stain"
* Iron Maiden "Fear of the dark" and "Brave new world". "No prayer for the dying" should also be okay, although I haven't tried with that album.
* Aerosmith "Get a grip"
* Ghost "If you have ghosts" EP
* Dire Straits "Brothers in Arms" (original CD from 1985)
Many other records are also cut flat from the CD master, so you can easily find another record to do this.
As you might know, the frequency response of MM cartridges changes with the amount of capacitance, while MC cartridges seem to be immune to this, but MCs can be sensitive to the amount of ohms that you load them with, although testing this with an Audio Technica AT33PTG/II showed that this particular cartridge didn't change its frequency response when I changed the ohm load anywhere from 75 to 1000 ohms.
Anyway, the most neutral phono cartridge I have ever come across has been the Nagaoka MP-500, which is an MM cartridge.
This is the chart I made (the phono preamp was an NAD PP-4). The steep increase at the lowest frequencies is simply rumble, which is the case with all the pictures in this post:
I actually preferred the sound of the slightly less neutral Goldring Elite, so when I had them both on trial I ended up buying that one instead, as the slight spike around 10 kHz on the Goldring gives the music a nice sparkle. Please ignore the drastic increase at the very highest frequencies. I don't know exactly why this showed up:
Two other very neutral cartridges that I haven't tried myself are:
The Dynavector - DV XX2 mk2 (measured by Hifi Critic):
And the Hana EL and Hana EH (EL is low output, EH is high output):
Just for comparisons sake, here' the Hana SH (shibata, high output), which I tried out:
Eventually, I replaced my Goldring Elite with an Audio Technica AT33PTG/II, which is even less accurate, but something just didn't sound right with the Goldring Elite. It could have been distortion. The Audio Technicas are known for being some of the best trackers on the market, although I haven't examined this myself. Here's its chart - not so noticeable is a very slight dip in the harshness region:
Just to compare, here's my other current cartridge, the Audio Technica VM750SH with NAD PP-4 phono preamp:
With my new Mofi Studiophono preamp it looks slightly different, which I think is due to less capacitance in the Mofi, as it seems that the higher capacitance in the NAD pushes down the harshness region slightly, increases the big spike a bit, and also pushes down the very highest frequencies (the roll-off after the spike) a bit. Although it's not a big audible difference, I did pass an ABX test with the two different phono preamps:
Although the VM750SH is an MM cartridge, many MC cartridges have frequency responses with big spikes around 10-15 kHz like the charts above.
And also for comparisons sake, here's the cartridge I had a few years ago, a Rega Exact (MM):
Despite the uneven curve, this frequency response made many bright records sound really nice.
Then, here's the much-loved Denon 103:
And a cheap Audio Technica AT-VM95E (there are many different types of AT-95 with different letter combinations at the end, depending on the stylus tip):
Then, just to finish off, Lyra cartridges are some of the most expensive cartridges on the market, and some people consider them some of the finest cartridges money can buy.
Here are a few charts:
Lyra Dorian (measured by TNT audio). Notice both the boost in bass, slight dip in the harshness region as well as the obvious increase in the highest frequencies (the drop-off might be due to the test record):
Lyra Delos (the replacement for the Dorian):
Lyra ETNA SL (measured by Hi-Fi News):
Lyra Atlas, their most expensive model (measured by Stereoplay):
