Temp of Benchmark DAC3?
12Many
How hot should the DAC3 run during normal use? Mine DAC3 is hotter then the AHB2 amp. They are side by side in a cabinet. Lots of space on the side and top, the front is open to the room. I measured the temp of the DAC and it was about 102. Amp was about 98. Room was about 78. Does this seem reasonable? My system has not been sounding as good of late but it could be my ears. Thanks.
rgpit
Colorado Springs, CO
I would contact Benchmark. They will give you the best answer.
RayDunzl
Central Scrutinizer
Riverview FL
My DAC2 HGC reads 102 on the top of the case, and probably has for 10 years (always on).
I don't worry about it.
Sutton
My DAC 3 HGC runs hot too, but doesn't appear to affect sound quality.
anmpr1
Same here. I think its normal. The amp, BTW, has massive heat sinks. With fairly sensitive loudspeakers mine never gets much above room temp. DAC3 HGC is always warmer.
Owl
I have the same two units and my experience is like yours. Just guessing here, but if you listen to the DAC you can hear the power supply, but not the amplifier. Clearly a completely different design for obvious reasons.
1
12Many
Thanks all. I appreciate the feedback.
