I know the thread is old but ESS are clinical sounding and I am also a fan of Burr Browns..
Define clinical sounding. Do you mean accurate reproduction without added distortion or "color"?
If you are just interested in people's subjective opinions here is one comparing ESS and BB... his opinion is the opposite of yours, but he does describe it in great detail and uses an interesting platform with which to make the comparison.I know the thread is old but ESS are clinical sounding and I am also a fan of Burr Browns.
How do you propose they sound different. (Before I go off about they don't.)I know the thread is old but ESS are clinical sounding and I am also a fan of Burr Browns.
Sure. Here's a DO-300 sine wave at -100dBFS. That's quiet, but perceptible, especially with good fitting headphones. The AP2722 analog plot exhibits self-noise at this level, so we developed a special measurement technique. I can share the signal path if anyone's interested. Every other single-path DAC we've tested at -100dBFS looks far worse than this plot. Some are just pure noise, including a >$20,000 DAC, which will remain nameless.
They are warmer and sound more relaxed and yes i've abx'd blind.How do you propose they sound different. (Before I go off about they don't.)
Well if you've blind tested then I could argue but I'm not because you did a blind test. How big was the difference? Was it obvious or subtle etc? I am very curious.They are warmer and sound more relaxed and yes i've abx'd blind.
YesDefine clinical sounding. Do you mean accurate reproduction without added distortion or "color"?
Not really the Burr Browns are warmed and more relaxed, sort like the difference between my Hd580's and 400i's.So you are saying they are bad at accurately reproducing the music and the bad design adds distortion you prefer?
It is easy enough to pick out.Well if you've blind tested then I could argue but I'm not because you did a blind test. How big was the difference? Was it obvious or subtle etc? I am very curious.
IC. What age where these DACs? Are they new gear or dated? I'm trying to understand this.It is easy enough to pick out.
The burr's are at least 10 years old, ess is newer as well as an akm.IC. What age where these DACs? Are they new gear or dated? I'm trying to understand this.
IC. Interesting. It could be that the technology has improved that much over the ~10 years and the peripheral audio circuitry is lacking compared with the newer audio ICs. It would be very cool if you could send that old DAC to @amirm for a test. To see what is going on.The burr's are at least 10 years old, ess is newer as well as an akm.
Much older than this thread, is testimony like yours being offered as sufficient evidence of sonic diffence between DACs.I know the thread is old but ESS are clinical sounding and I am also a fan of Burr Browns.
Thanks. I checked my notes. The waveform I shared was 30uVrms, which at 5.2V max I think is -105dBFS. What system are you using to capture a visual waveform? And what preamp for the +60dB gain?That does look much worse than it should. Here's DO300, -100dBFS signal captured without an AP, with 60dB amplification and low-noise ADC:
That remindes me of homeophathic treatments - the active ingredient is extremely diluted but if you believe it works, it might just as well.In the pro audio world, we listen to reverb tails. Pathological, indeed . We listen to music and ambience until the moment we lose perception. Of course, recording levels this low are only as good as the recording itself (room, mic, adc, pre, technique, program, etc). Some studio friends did a DAC shootout in L.A. a while back, like 25 DACs. Blind. They listened only to complex-pulsed reverb tails, at levels most people (perhaps like yourself) would never consider. Hugely revealing. Very-low-level DAC performance impacts atmospherics and timbre purity. Recording engineers know that imaging and depth is best perceived in the very quiet passages, and DACs with the best very-low-level waveform purity deliver the best spatial reality.
Can you record the same song twice and make the recordings downloadable ?It is easy enough to pick out.
But is not the low level performance excellent in most modern DAC’s anyway ? Amir does not do the -100 or -90 dB sine test but it can be inferred from his other test for example linearity that this must be the case .That remindes me of homeophathic treatments - the active ingredient is extremely diluted but if you believe it works, it might just as well.
What can you say that supports your claim that very-low level performance has in impact on timbre purity and spatial qualities?
