Roland68
It's exactly as you say.The SMSL sdb setting is identical to using the tone controls with treble at +4 dB and bass at +5 dB - at least in my ao200 (measurements in this thread). And those tone controls come 'for free' in the analog volume-control chip they use in many of their products. There is nothing magic about it, and I suspect you can adjust the bass and treble controls on the A30a to suit your preferences.
SDB is not a magical setting of SMSL, but just a combination of the existing setting options for the tone controls and has nothing to do with DSP.
It is very noticeable that the NJW1194 chip is used in almost every device with an SDB.
This analog chip cannot be used in the A30a because the processing is completely digital and the analog input is also converted directly into digital.
Based on past experience, it is better if these companies work as little as possible on the firmware (I'm just holding back a bad word) so that unnecessary errors are not introduced. Just the fact that the specified possibilities of the ICs used for 2.1 were not implemented properly... A simple series of measurements or listening session at different volumes would have shown that something was wrong.
So don't cry that the "magic" SDB isn't there and find your own setting. Or use one of the 31 presets (not from SMSL), the 32nd is the default setting Flat.
