RME ADI-2 DAC FS - AKM Versus ESS Measurements (DAC, Preamp & Headamp)
Holmz
Australia
More data:
As expected, cheaper Topping performs worse.
RME UCX II is doing pretty good.
At that level, you'd have 2,4% THD for the G5 and 0.4% for the D90LE.
And THD would be close to 0 (<0.01%) for the RMEs.
And i thought it was all just 1s and zeros… :rolleyes:
Because of the formatting I ask, is the one without the hole by the power supply connection the newer ESS chip model? Thanks
alekksander
NRN PL
excellent measurement raport. helped me with the decision. bought used AKM version cause it was available for reasonable price locally. nice device over all. not a big fan of it's display, but it's not that bad. wish auto dark mode leaves some sort of indicator that helps to recognize if the device is even plugged-in. and auto–on on signal would be also VERY desired.
Anton S
excellent measurements. helped me with the decision. bought used AKM version cause it was available for reasonable price locally. nice device over all. not a big fan of it's display, but it's not that bad. wish auto dark mode leaves some sort of indicator that helps to recognize if the device is even plugged-in. and auto–on on signal would be also VERY desired.
If the display is intrusive, you can just turn the brightness down low instead of using auto dark. It's adjustable from 20% to 100%. Default is 80%.
alekksander
NRN PL
done that, but 20% is still not enought for me. also rings could be slightly dimmed. probably have to change placement of the unit so it doesnt point at my face.
Svperstar
I absolutely love my RME-ADI 2.
I've been in the market for a balanced solid state amp that has end game power for ANYTHING you could throw at it. I heard the HE-6 at a meetup and my SP200 barely powered it properly.
Has anyone else got a crazy powerful balance solid state amp to pair with the RME ADI-2? What did you settle on?
D!sco
I imagine any of the THX amps or top grade toppings will do it for you. Schiit's going for up to 5W class AB on some of theirs now with perfect measurements (or tubes)
Svperstar
I own a THX SP200, not strong enough. I've been on the fence about Violectric amps for months. The Schiit Midgard came out of nowhere and seems to check all the boxes.
I just tried my Midgard with the HE6se yesterday and it did very well. With the ADI-2 DAC set at -10db on the volume dial I was between 50% and 75% on the Midgard’s pot depending on the volume level of the music.
ArturoKiwi
Great comparisons and really a great work!
I always think that RME dac has a very good implementation and a used one cost more or less as a new Topping or SMSL but they are more reliable.
What stop me to buy it is that I'm afraid of the EQ. Absolutely a great feature, but I'm afraid that I'll not use it because of the difficulty to set it up.
Svperstar
It's easy to setup with the Remote app, you can import EQ settings
ArturoKiwi
I'll going to search some tutorial to understand the how to.
Thanks for the information
gvl
SoCal
The EQ functionality on the device is not too difficult even when using physical controls but you need to know your target EQ settings. For headphones this usually means finding them from the measurements someone else did, which is even if not final is a good starting point. For speakers you’ll need to perform measurements in your room with a mic and a software package such as REW that can get a bit technical. I suppose what I’m trying to say if your main use case is headphones then EQ is easy, speakers require more work and understanding of the technicalities.
I use the EQ less with headphones; but set the crossfeed feature to 1 or 2; and change filter selections now and then. Currently set to NOS and I'm using Neumann NDH-30 headphones through the Midgard using the RME as DAC and pre to a point. Everything sounds great. The Midgard is a little easier on the ears mids on up compared to the RME, material dependent. Personally, there is a curve to learn how to use the RME. I'm no keener, maybe a geek at best, but I've mastered the RME and it's a cakewalk now. I always say to folks, if I can do it, anyone can! :)
ArturoKiwi
I would like to use it for the speaker 90% of the times
ArturoKiwi
Then you'll need a measurement microphone and ramp up on REW. This is no rocket science but there is a learning curve, you can find a tutorial that should get you going.
I read something in the past, but I didn't understand was which house curve use.
If I'll use REW, then I'll need to export the filter file and import it in Remote app. Is it right?
gvl
SoCal
I haven’t used the remote app yet, I think it’s relatively new. The old way of doing things was to have REW generate PEQ settings based on your measurements and the target curve and then enter them by hand on the RME.
ArturoKiwi
Which target curve do you use?
gvl
SoCal
None at the moment as I’ve been lazy to EQ my last acquired speakers and they sound pretty good even w/out EQ. I used the Harman curve in the past if memory serves, you want the room response to tilt down with frequency otherwise speakers sound too bright. It may even have been a default preset in REW that looked reasonable out of the box, it’s been a while… Start with something established like harman and see if you like it, you can and should fine tune to taste.
You don’t need to buy the RME to play with EQ/REW, just use a PC software player that supports PEQ or convolution filters.
