Rega DAC-R DAC Review
Rate this DAC:
    Votes: 241 72.2%
    Votes: 71 21.3%
    Votes: 12 3.6%
    Votes: 10 3.0%
antcollinet
UK/Cheshire
Measures pretty bad, I currently run one and it sounds OK to my ears. Would there be an audible difference between the Rega and something like the SMSL SU1?
Probably not. It does not measure badly enough for the faults to be audible in most real world listening situations.
Billy Budapest
A DAC has to be doing something *really* bad in order for it to be audible.
DSJR
Suffolk Coastal, UK
Seriously, don't even go there 'cos there be dragons in such a discussion...
If a possible replacement is to be considered, look at the practical things such as facilities, proper variable balanced outputs for future active speaker purchases :D, display or not, build, getting it serviced if needs be and of course looks :) Sound quality has beggar-all to do with it when you get to SU1 level and above :D :D
Nango
D:\EU\GER\Rheinhessen
yes, it went to court. i complaint against the dealer because i had a lot of trouble with the devices and he refused to take them back. i live in the EU so we have a thing called "gewährleistung" which protects the customers for 2 years on newly bought things. so i contacted my law insurance, they proceeded to take legal actions against the dealer and the court requested an expertise. that was created and i was proven right in court. unfortunately, the dealer went insolvency. lucky me, the law insurance paid all that (including the expertise which was about 600 EUR or so).
Lucky germans with their Rechtschutzinsurance, the only one insurance you really need in life!!!!
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
The power supply issues were in fact audible, see the reviews
Can you point to where in the review that is indicated?
Do you believe you can hear PS noise more than -110dB down?
YouAreBiased
Well documented on this forum, as well as Hoffman forums. Also in the original stereophile review and measurements.
Purité Audio
Industry Insider
Barrowmaster
London
Still -120dB 2nd harmonic is higher, and only one man on earth can hear those - levels! Oh and his girlfriend.
Billy Budapest
I used to own the original Rega DAC and I did not hear any such power supply noise. It would have manifested itself as a 60 Hz hum and multiples thereof.
BDWoody
Chief Cat Herder
Moderator
Reactions: EJ3
thegeton
Manchester, WA
Please provide the links. No links = never happened.
Billy Budapest
Other than photos of systems, that place is a hotbed of insanity. Crazy subjectivity^10
Great place for discussion about music. Possibly the worst place for discussion of hardware. I’ve been a member there for 20 years, since it was a lot smaller in membership, and it was a lot more enjoyable then.
