Anton D
- Joined
- Mar 17, 2021
- Messages
- 863
- Likes
- 993
At what point does SINAD lose relevance?Agreed.
At some number, when do we no longer care?
I don’t know, by the way!
If my recollection serves me right, according to one of Amir's post, I believe the threshold of hearing is around 110 SINAD? I could be wrong though.At what point does SINAD lose relevance?
Thank you!If my recollection serves me right, according to one of Amir's post, I believe the threshold of hearing is around 110 SINAD? I could be wrong though.
Should have ignored it. Won't happen in use in a car!
Also, it should not have been allowed to bring SINAD or resolution down.
Otherwise, great, thanx.
In reality though, if SNR is high enough, the limit is probably much, much lower. I doubt that anyone can reliable double blind this amp vs Topping LA90D or Benchmark amp given that both amps stay within their power limits. SNR isn’t top notch though, so maybe with high efficiency speakers the noise might give it away.If my recollection serves me right, according to one of Amir's post, I believe the threshold of hearing is around 110 SINAD? I could be wrong though.
The amp has an SMPS onboard, so it should be immune to all electrical noises through powerlines.It may very well be much much worse in a car. @amirm should really up his game and weld a steel frame, connect the amp with a 5 m. cable to a battery + terminal and a 10 cm. negative to a bolt on the frame and let a gasoline (15 kV ignition transformer) engine pull a 12 V generator. There is so much more electrical noise in a car..
Yes, me too!I have an old (over 20+ years old I believe Sony 4 channel amp I could send. Believe I have an Alpine as well. I have a crate of amps, head units, speakers, and active crossovers left over from those days...I miss installing those systems. Cars these days are so complex with the audio system integrated w/ the backup camera, security, GPS, etc it's almost impossible to modify one. I may send the Sony in if @amirm wants to measure it. These car amps probably aren't a time drain like an AVR so maybe?
BTW, the owner let me know that there is a panel you remove which then lets you set the gain and filters. This would have allowed me to get good channel match.
Great measuring car amp.
To bad about the low efficiency (for class d)
I'd be on the fence as in my car I really value efficiency and then the price is more than many current non-McIntosh products... and honestly don't exactly need measurements to be this clean for the car.
Thanks for the recent car gear tests.
Yes, me too!
Upon reading @amirm's review, I moved both our cars out and I tore up the whole garage looking for that crate, but two hours later; I gave up the search.
I know that somewhere in the bowels of our garage, I have a few multi-channel powerAmps but I cannot even remember the brand names. Sony CDX90 is/was the head end.
Sounds like a solid design!Hi guys,
I sent this amp in to Amir. I've been refurbishing McIntosh car amps for a bit, validating my work on a QA401 analyzer, but these amps were measuring (for me) such low overall THD+N I knew I had to send it in to Amir for a spin on the mighty AP! Anyway, here's some further info about this amp:
- It was a restoration project for me. It had acid-based damage on multiple traces due to leaking electrolytics. I replaced all of the electrolytics with appropriate Nichicon capacitors (FG, ES, and UPW) you can see in the photos.
- From studying the design (and some rogue service manuals I found the web) the pre-amp stages have dedicated, highspeed non-signal path op-amps to detect and cancel noise and harmonics in the pre-amp stages, a McIntosh special I think. (Maybe the reason for the higher cross-talk?)
- The output power stage has 4 stages that I can identify - a differential stage, followed by two voltage stages, and the final current stage. It is class AB with a heavy A-bias (for a car amp). That's why it draws 7A for 5 watts output. There is no global negative feedback - the negative feedback for the output stage of each channel is only reflected back to the first differential stage in the power section.
- It does have a special protection feature called PowerGuard. Which is maybe what Amir saw in his 200Hz sweep. It activates the yellow LED. What happens is, when the onset of clipping is detected on the output of any channel, the signal in the pre-amp stage is proportionally reduced to maintain less that 2% THD and prevent clipping at the output. It looks super weird on a scope - you can increase the input, see the output grow, until the output just stops, holding a steady sine wave just before clipping. With my QA401 analyzer, I had to set my THD+N sweep stop setting to -60dB (0.1%) instead of 1%, as the amp itself would pull back the clipping, causing the analyzer to just keep increasing input level until it reached the top step of the signal to the amp.
Attached are the measurements I was able to take on this amp before sending it to Amir. It looks close but the QA401 is definitely no AP test rig Plus I wouldn't necessarily consider myself a professional in the measurement department like Amir
Thanks for sending it in. It's great to see some unique and high-performing audio from the past.Hi guys,
Pair of MC830's for sale over at The Music Room for a decent price!I for one would love to see more McIntosh stuff tested here. I do understand it is very expensive and a lot of their portfolio is out of the realm for most. However some is within reach especially in the used market and. I have been hoping to catch either a pair of MC830s or one of the Mc462 used after seeing @hardisj review on Erin's Audio Corner. I think it would be perfect for My KEF Reference 5's and a great replacement for my Yamaha M60
They did make one car amp with the autotransformers... the mighty MCC602TM. 300w x2 at 8,4, or 2 ohmsHow about that, a McIntosh amplifier without their "Unity Coupled Autotransformer" output stage.
