March Audio P452 Purifi Based Stereo Power Amplifier
Status
Not open for further replies.
March Audio
Albany Western Australia
Finally available. Will post more later :)
https://www.marchaudio.net.au/p452
restorer-john
Looks good. The only thing you could do is add 10mm pieces of black glue-lined heatshrink to the ends of the woven polypropylene and it'd be worthy of RGB lighting like a gaming pooder with a perspex cut out lid.
(Hey, there's an idea for the next HiFi show...Audiophiles love cut-aways and perspex windows to see the innards) (I'll take a P-452 for that idea.)
Matias
São Paulo, Brazil
1,600 usd, great!
kaka89
Can customer "easily" adjust the gain by themselves by replacing resistors?
March Audio
March Audio
I wouldn't say "easy", it is 0603 surface mount, but if you have the tools and skills.... Have to point out it would invalidate the warranty.
However we can set the gain to anything you like at manufacture to save you the trouble :). Just contact us with your requirements.
DSJR
Suffolk Coastal, UK
Hope you don't get mangled by current international shipping rates. Hoping it'll calm back down as flights increase again.
Sal1950
The Chicago Crusher
Central Fl
Very nice, I'm sure it will be very popular.
How about a version in a bigger case and a couple sexy VU meters upfront.
Or monoblock version with a single VU.
I venture a guess a 30% increase in sales. ;)
restorer-john
Here you go Sal. ;)
A pair of Sony TAN-77es the same as mine. Run the pair in mono and get ~600wpc@8R and ~1KW@4R. Each meter is over 6" diagonal. 26.5kg each- 53kg for the pair- you need a decent shelf. I have mine along the top of a solid timber buffet. You don't really want to stack them in summer- they run pretty toasty.
(not my pic)
thanhh
Here you go Sal. ;)
(not my pic)
They are gorgeus but last I checked, they fetch around $3000 aud each on eBay and good luck finding them
Money per wattage + performance, I think it is very hard to beat these new purifi based amps.
flyzipper
Ontario Canada
To power the LCR channels in the home theatre, that'd take...
  • 3 x P451 @$1,165.50/per = $3496.50
OR
  • 1 x P451 @$1,165.50/per + 1 x P452 @$1,600.00/per = $2765.50
A difference of $731.00
Since both setups would be driven by one Purifi 1ET400A per channel, does the cost difference come down to the case expense, and the additional labour to build/test/ship 3 amps vs 2? Or, is there something material to performance which would make somebody spend the premium for 3 P451 monoblocks?
TL;DR - Other than the aesthetic preference & placement flexibility, is there an objective technical benefit to 3 x P451 VS 1 P451 + 1 P452?
flyzipper
Ontario Canada
PS... you might want to indicate L, W, H for the dimensions on your site, or label them in a consistent order.
P451 - 330mm x 180mm x 75mm (LxWxH)
P452 - 360mm x 200mm x 85mm (WxLxH)
... but one is narrow & deep, while the other is wide & shallow.
Status
