Hi all,
just got a used KEF Kube 10b.
Because its sides are full cloth wrap, I was interested how it looks inside.
You can see from the images it's not a standard sub box.
Top and bottom panels are removable because of the cloth, and the woofer is installed from inside.
The dampening material is closed cell foam sheet, no fiber or any other type of wool.
I didn't see that before in subs, so I have to imagine KEF was being cheap with the choice of dampening material.
The box itself is made from 3/4" MDF, the front is 1" MDF. The woofer screws are with threads mounted on the front side, so the grip is strong.
The top and bottom panel don't have any type of gasket, they are just screwed on the box.
While listening to the sub, there is no any type of strange noises coming from it, so it's probably made well enough.
The woofer unit is very similar to the B&W ASW608/610 models.
As for the sound itself, in my setup it sounds better than SVS SB1000 Pro.
I might try and do some DIY on it, change dampening to wool, make some bracing and maybe brace the woofer magnet.
