No problem. I'm curious to see his response. There are arguments in favor of his position.Debate, please. There are too many fights going on around here at the moment, without you two starting another.
And I will answer your repeated question: no, I don't believe that the studies you question are, for the most part, compliant with ITU-R BS.116. I'm not sure that, for the broadly investigative purpose that @Archimago is following, he needs to use an industry standard.
(Mods please feel free to move this OT diversion)I am, however, curious as to when positive controls are not a good thing.
You've been here.... what..... about 5 minutes?Understood. If you feel like you don't have the qualifications to answer the question, that's Ok. And better to make that judgement than to over extend yourself.
In my time working with standards bodies for the US Federal government I gained deep insights into a few organizations' standards development processes. My technical work was in advanced programming language architecture using type theory, category theory and proof theory.
I am a veteran of many, many discussion groups on a wide range of topics. I think I have a pretty good read on this group at this point.
It depends STRONGLY on the question to be answered. For example, if I'm testing to establish a jnd (whether level, frequency response, compression artifacts, localization...), then a positive control is vital. But the positive control is something above already established thresholds and (and this is key) it is the same phenomenon we're testing. For a trivial example, if I'm testing for jnd level differences, I slip in something (say) 1dB higher in level. If that's not detected, the test (or the listener) lacks sensitivity. Any results from that run of tests with that listener are usually discarded.
Are we agreed so far?
OK, so we agree so far.Absolutely. The key is the italic text. It is easy to make a bad control. Say, use 4 bit PCM piano music as the control.
Now, suppose the question to be answered is, "Can Audiophile Cletus hear the difference between copper and silver wire that he claims he can?" Now, putting aside the issue of positive controls, that's an easy experiment (conceptually) to run- Cletus says he hears in on his Diana Krall LPs in his home system, "...clear as day. You'd have to be deaf to miss it!" We swap copper and silver randomly and see if he can identify or sort or however you structure a DBT.
What's the valid positive control? Materials? No-one has demonstrated that they can hear the difference between copper interconnects and a potato (an actual test someone ran!). Level? You're not testing for level so sensitivity to one variable is no indication of sensitivity to another variable. EQ? Ditto. Whatever positive control you choose is going to be a different phenomenon.
So I would argue that this is an example of a valid test to answer a specific question where a positive control is both unneeded and impossible.
My next step will be to by an avr equipped with a 96khz capable dsp.
They are not so many on the market.
Noise. But the point remains, positive controls are appropriate where they're appropriate, but they are not always appropriate for validity.Of course, we know where that leads.
That is true. Perhaps I need to specify "for effects that can be varied meaningfully".Noise. But the point remains, positive controls are appropriate where they're appropriate, but they are not always appropriate for validity.
Interesting logic. What you've done here, is change the place where the conversion from 96/24 to 48/24 takes place. You aren't suddenly hearing the 96/24 file. So, assuming that the difference exists in the sound waves - and that, as we know here, is not a given, since you don't report a blinded test - all you can have shown is that the conversion in the Firestick is not as good as the conversion in the AVR.Let us take a practical example: Amazon music HD with an old avr 24 bits/192 khz dac.
I am listening music in 5.0 configuration.
The avr dsp will in any case run at 48 khz.
Because I am using a Firestick configured in DD+, the data rate is by default 16bits 44.1 khz or 48 khz by default.
I recently discovered a trick that force the firestick to send a stereo high resolution sound to the avr input.
Do I hear a difference?
Answer is yes: the sound is more detailed, as if a veil was removed.
But it is very subtle.
For sure there is no difference if it is car audio listening or earbud.
.... Now, suppose the question to be answered is, "Can Audiophile Cletus hear the difference between copper and silver wire that he claims he can?" Now, putting aside the issue of positive controls ...
Oh, I'd really like to read up on this test . Is it online somewhere?....No-one has demonstrated that they can hear the difference between copper interconnects and a potato (an actual test someone ran!)....
I think it was posted at diyAudio. A user there with the handle Pano ran it. IMO, he did a very good job and it was a clever idea.Oh, I'd really like to read up on this test . Is it online somewhere?
I was just using this as an example- it could be any kind of oddball claims (including those outside of audio like dowsing, precognition, telekinesis, whatever). Now if something mysterious gives a positive result, that's when things are interesting. Sadly, none of the mysterious stuff has ever held up to scrutiny.This is an audiophile topic that never stops giving fireworks.
But they have years of experience arguing with strangers on the internet. That's got to count for something, right? Argument from argument-authority?A little late to this, but is there anything more tedious than a new member who comes in hot bragging about his expertise? It was just the cherry on top that he had no idea to whom he was bragging, in this case.
Anyway, I found it entertaining.
