Mister_magister
- Joined
- Apr 19, 2023
- Messages
- 52
- Likes
- 19
I'm talking about RCA/XLR line out/in. But from the beginning
I have home theatre setup with adam t5v as LR, amp for the rest of the speakers and Asus Xonar u7 mk2 dac. At first there was issue where t5v's weren't getting loud enough at full volume on the DAC so i bought some cheap chinese preamp pcb and that solved the issue for t5v's. Someone recommended me to buy focusrite 18i20 because it has 4V line out and that would be perfect for t5v.
Now here's where confusion begins, because stupid me decided that he wants to understand this and math just doesn't make sense. So to gather information:
t5v has SE/BAL input which you can choose between and the switch also changes input sensitivity from -10dBV/+4dBu (yes it's cursed, move along)
Xonar has line out SE 1 Vrms (2.828 Vp-p)
18i20 has line out +16 dBu, balanced line out (and if i get SE it's halfed i imagine [correctmeifi'mwrong])
converting units to the same ones (dBu/Vrms) and talking only about SE, using this https://sengpielaudio.com/calculator-db-volt.htm
and my xonar has 1V rms out so that should be 3x more than enough to get the t5v loud enough right? well it's not not by a long shot
and 18i20 would be sending 2.4Vrms which is INSANELY higher than 0.3Vrms,
How is it okay to send that much voltage on something that has 0.3Vrms senstivity? Why isn't 1Vrms enough for 0.3Vrms? Why doesn't math add up? Did the audio engineers do meth instead of math? Some kind soul please explain to me what am I missing here
PS: t5v on bal get +4dBu of senstivity which is like 1.2Vrms which is "Studio level international" i saw on the website, but then focusrite spits out +16dBu which is 4.8Vrms which is 4x more what is even going on
- t5v - has -7.8dBu/0.3Vrms input sensitivity
- xonar - has 2.2dBu/1Vrms line out
- 18i20 - 16dBu = 4.8Vrms /2 = 2.4Vrms / 9.8dBu
