Hard time deciding which Integrated Amplifier to pick!
rdaow
EU
Yes, no doubt about that. I guess what I meant is that for me in the EU it's more convenient to buy from an EU store.
aaronsarkissian
Yerevan
If I’m not mistaken Schiit has few shops other than their US website where you can order too.
And the shops handle the shipping, warranty, etc.
I believe there should be one in Europe. If so and you like their products, you can go on.
Edit: here is the info that I found
JiiPee
Check Exposure 2150. No XLR-inputs, but otherwise matches Your spec:
- 75 W pc at 8 ohm (audio.com measured 80 W at 8 ohm and 121 W at 4 ohm)
- phono input
- AV input (direct connection to power amp)
You can find a review here ( in polish, but at least You can see the measurement results):
Review
Another interesting option could be Fezz Torus 5050 / 5060.
