Fun with vinyl measurements
Balle Clorin
Balle Clorin
This may be due to a damper, when setting up the cartridge, during assembly, the damper applied more pressure on one side than the other.
But then maybe different anti skating should make a difference? Different stiffness in each 45degree movement may misalign the moving generator part.Less relative movement in one direction should give lower signal I think
mfalcon
I’ll pull out the Wally skater tonight and test with a different test disk. Thanks everyone for the suggestions.
mfalcon
I dialed in the anti skate a little better but it wasn't too far off on the Wally Skater. Roughly similar results. Then I double check that the capacitance on both channels where equal.
That was it.
I feel dumb.
Balle Clorin
Balle Clorin
You are not dumb. Vinyl has its problems, you are just seeing it first hand. The perfect cartridge does not exist , and few records even test records are good enough. The medium it not better then 1-2db plus or minus. See my post above. You can try to play with Azimuth and VTA but in the end everything is a compromise. And compromises I fix with DSP…
I have spent 2000 Euros on test records and cartridges the last year and all of the records and cartridges/ styluses has flaws. I have returned 60% of the cartridges/ styluses due to geometrical errors way outside of specs that are quite mediocre already. Money does not help in this hobby, but knowledge and learning does, and you just learned something useful the hard way. I do not mind the hassle and expenses, I do not have a holiday home or care about a fancy car and cannot do any physical sports, or gamble or cheat … I like to have some interesting hobby and Vinyl and Acoustics keeps me busy learning. Better to do it now while I still can hear and before I die ( yes I almost did twice the last 5 years) Sex drugs and rock&Roll is still good even with 1db off above 10kHz!.
I apologize for becoming philosophical..
Balle Clorin
Balle Clorin
Nobody wanted this Mint and sealed Denon XG-7001 reprint by RTI as 180grams, so I gave it a home.
I will wait until my cartridge is inspected before playing it.
I also got a visually nice CBS STR-100 .3 today, since many use it I wanted it too, for comparisons
Balle Clorin
Balle Clorin
Not sure if the new FR from CBS-str100 ver3 on my AT33PTGii should go to the Cartridge library thread-( I posted with other records there).
Definately poor balance 1db on my cart...across all records it vary..
But I can now conclude that all my 3 CA TRS-1007 for sure have an unusual drop in left channel above 10khz, do not se that drop on the Din or CBS
The refence DIN45543 gives 0.5db unbalance and less sub10k drop and higher peak
Comparing Left and Right with the DIN reference gives this
My Jico SAS B looks very untypical also on the CBS STR-100. It looks like the Pivot point of the cantilever is wrongly placed? se article below
narud
doesnt that look kind of similar to what @mackat got with the sas/b on a type iv?
Thomas_A
Sweden
Yes , but less pronounced drop I think, my CA TRS-1007 posted below his looks different, dropping all the way no peak
Post in thread 'Introducing the Phono Cartridge Measurement Library'
https://audiosciencereview.com/foru...tridge-measurement-library.46108/post-1847291
Did you try the Ortofon sweep 800 Hz - 50 kHz? While it seems poor and drooping below 2 kHz you could align it to 0dB at 2 kHz and look at the response 2-50 kHz. Just to see how the response look like above 20 kHz.
USER
Since you have gone so far with all these test records, you may as well try a record flattener. It may help with some of the discrepancies --though of course you'd want to be careful at the beginning and don't expect miracles.
Any recommended products for that task?
Balle Clorin
Balle Clorin
SHURE V15-IV SAS-B 1.5g brush down on Denon 51F, 800-50 000 Hz, Good idea to try the Ortofon, maybe not as useless as I thought at first
AT33PTGii for comparison
And against the Reference - left channels and right to the right. Pretty good record for above 2000hz and to 20k, YESSS!
Thomas_A
Sweden
This is my result for the SAS/B on the V15Vx body (peaking a bit lower in fr than with yours that occurs just above 20k). So there is some variation where the peaking occurs.
A new stylus is on the way (have had a conversation with the retailer of the previous SAS/B with poor crosstalk, and they also agree and have measured a new one that "hopefully" will be better on the V15Vx; I'll report back).
USER
Record Pi or Vinyl Flat, former is supposedly a little heftier (but more expensive).
Examples of results here:
JP
Brookfield, CT
I’ve both. The record Pi timer and app are handy, but are generic devices that can be bought very cheap.
atmasphere
Have you all paid attention to loading of these cartridges? The inductance in parallel with the tonearm capacitance can cause a peak at high frequencies. You can iron that out...
mackat
Nagaoka MP-500
I know that this one has been long awaited! With the yen so low, I decided to finally purchase one through CDJapan last month.
According to the Hi-Fi News review of this cartridge, "The flagship of Nagaoka's 'Moving Permalloy' range can trace its lineage back to ADC's 10E pick-up from 1964."
From the measurements done by Miller Audio Research in that same review, we notice something a bit peculiar about its frequency response. It shows a gradual peak from 1 to 6 kHz, followed by a fairly drastic slope downward that reaches -7 dB at 20 kHz!
There are some other measurements floating around which show a similar phenomenon, as well as older Nagaoka measurements that do not.
What does the Nagaoka MP-500 as sold today's frequency response look like?
Here are some graphs showing measurements I've taken with a couple of different turntable, tonearm, and phono preamp combinations, along with some variations in azimuth, VTF (2g is a typo, it is actually 1.8), and VTA:
Nagaoka MP-500_1.6 g_~200 pF_50k Ω_CA-TRS-1007 #1 - Side A_norm1_1_17 Beta.png
Nagaoka MP-500_1.8 g_~130 pF_47k Ω_CA-TRS-1007 #1 - Side A_norm1_3_17 Beta.png
Nagaoka MP-500_1.8 g_~250 pF_50k Ω_CA-TRS-1007 #1 - Side B_norm1_1_17 Beta.png
Nagaoka MP-500_2.0 g_~80 pF_47k Ω_CA-TRS-1007 #1 - Side A_norm1_1_17 Beta.png
Nagaoka MP-500_2.0 g_~80 pF_47k Ω_CA-TRS-1007 #1 - Side B_norm1_1_17 Beta.png
I would call that extremely flat! No sharp downward slope to be seen here. Likely one of the flattest cartridges available for purchase new today.
Distortion is a little high compared to the best we've seen, but it's not bad.
The MP-500 tracked beautifully on the Ortofon test record, only mistracking at the highest 100 µm test track, IIRC. Even this could possibly be ameliorated with more precise setup.
The compliance is almost certainly higher than indicated, as I get a resonance of ~5 Hz on the EPA-100 and ~6 Hz on the EPA-A250.
I still need to test it on an A501H with a phono stage that doesn't have an always-on subsonic filter.
So, what explains the totally different frequency response shown in other measurements? A production change? (possible) Unit-to-unit variation? (doubtful)
I certainly don't know!
One strange phenomenon I did experience on both turntables is an occasional, seemingly random, and very disconcerting sounding static discharge. A quick Google search will show that this has been reported by a number of people across the Nagaoka line of cartridges.
Someone responded to me on another forum that it is caused by static building up in the generator, and can be prevented by occasionally putting a drop of anti-static fluid or stylus cleaner onto the cantilever. I have not tried that myself, and, as always, YMMV.
All in all, I am very glad I decided to buy this cartridge to test, and am quite impressed with it!
Thomas_A
Sweden
Nagaoka MP-500
View attachment 358411View attachment 358412View attachment 358414View attachment 358416View attachment 358417
Thanks for this. Certainly a very fine cartridge, one of the best available as new today. Impressive frequency response and channel separation (high up in frequency also), marks a good manufacturing. Though a bit high 2nd harmonic distortion @ 5 kHz, would have liked to see around -35 dB. Perhaps due to that the stylus is not the microridge that is usually giving those low levels.
But otherwise very very good. But would need a low-mass arm...
Thomas_A
Sweden
You should add it to the library thread!
