Focal Kanta 2 vs KEF R7 meta
Mauro
I wouldn’t suggest kefs as floor standing speakers. They sound small, which doesn’t match the visual expectation. This doesn’t mean at all they are bad or not neutral. Actually they are very good. I am just saying that I would go for a floorstanding speaker with wider dispersion. (BTW I auditioned the R7 myself and went for revel’s)
30 Ounce
Both of these speakers measure quite well. It will ultimately depend on your room. I have heard the Kanta 2's on several occasions in well set up rooms and have never thought they sound bright or harsh. I think they could in a bright sounding room. The KEF's that i've heard have never impressed me much but I have not heard the R7 Meta's. If these are available at the same price I would choose the Focals every time. But if their list price was a consideration then the KEF's are truly a bargain.
vicenzo_del_paris
Brittany, France
,luckily by minute 3 I was getting a head ache,by the 5th minute it was like a screaming migraine,that’s not even a exaggeration.
The high frequencies in the room excited things in a way which I’ve never experience
Funny as these are opposite statements based on opinions :)
Probably either a matter of taste / issues with rooms / personal earing tolerance threshold
I will comment on this as I actually own a pair of Kanta 2.
My previous speakers were bright/harsh (Magnat Quantum 759 totl).
Not a personal opinion as it is backed by many, many measurements (that I can share if needed).
Prior buying them, I auditioned kantas 2 in multiple occasions in different rooms.
They never sounded bright to me (at that point, it was an opinion as I did not have measurements).
My untreated room can be qualified as bright and reverberant (lots of bay windows, floor tiles, ...)
Since, I have dozens of measurements of the kantas in my rooms showing trebles are not elevated. I shared an example in another thread about Dirac and I can share some if needed.
I am not trying to advocate for them at all.
I am rather trying to stick to facts :)
And instead rebutting myths/opinions about harshness.
These one have indeed a wide directivity compared to other ones !
deprogrammed
Dayton Ohio
I’ve only listened to the Kantas,if I’d have only listened for two mins I’d have forced them to take my money,luckily by minute 3 I was getting a head ache,by the 5th minute it was like a screaming migraine,that’s not even a exaggeration.
The high frequencies in the room excited things in a way which I’ve never experienced,I can imagine some people loving them though,after all it’s all a bit personal.
If a speaker gives you a headache you should see a Dr.
Robovox
London
Figure 4 from the Stereophile review of the Kanta No 2 shows some directivity error which may be the cause of the fatiguing brightness I have experienced with Focal speakers, albeit an octave higher than I suggested in post 14 upthread.
I suspect that, to some extent, we all have different sensitivities to the various factors which affect the perceived quality of a loudspeaker. The real-world significance of the 5-9kHz off axis bump will depend on the room and may be benign in some circumstances. Hence my belief that an audition is always valuable before purchase.
Having been a little disobliging about Focal speakers, I should say I heard the Focal Aria Evo X No.3 at the Bristol show on Friday and didn’t find them fatiguing - I got Daft Punk fatigue before speaker fatigue anyway and the lush high gloss green finish would suit my living room perfectly.
Nice to see they remain fabriqué en France.
dako
Previously, I owned a pair of KEF R11 speakers and have since upgraded to the Kanta 1 from Focal. While the KEF speakers exhibit slightly superior technical measurements, the most significant distinction between KEF and Focal lies in their sound dispersion characteristics.
KEF speakers offer a narrower directivity, making them an ideal choice for those who favor a concentrated soundstage with a distinct center. Conversely, Focal speakers present a broader directivity, catering to listeners who appreciate a spacious soundstage, thereby enhancing the listening experience with its expansive sound distribution.
Upon reflection, I discovered a preference for the broad directivity offered by Focal, particularly for its +60-degree range. This feature adds a subtle shimmer to the treble, which, although difficult to articulate, significantly enriches the audio experience.
In my experience, the Focal speakers stand out remarkably. They manage to avoid any hint of brightness, offering a neutral sound profile that is genuinely pleasing to the ear.
I also like their design :)
JohNChen
Hello Mauro, I want to upgrade my speakers recently, but I can't decide between f226be and r7 meta. Both speakers have excellent measurement results. Which one will perform better in a 15-square-meter room? Can you tell me which speakers from Revel you upgraded? Grateful.
Mauro
Hello! I bought the performa f206. Both speakers are great. I would go for the Revels but both have smooth off axis performance and perform well even if they have side walls close to them.
My experience with a similar room size is that you really need some form of advanced room correction (Audissey XT32 or Dirac). This is my most important suggestion. Otherwise both will sound boomy and dark, with strong elevation roughly between 60 to 500 Hz and tiu will not get neutral sound..
JohNChen
我会选择 Revels,但两者都具有平滑的离轴性能,即使它们靠近侧壁也表现良好。
我对类似房间大小的经验是,您确实需要某种形式的
Thank you for your reply! Yes, I am currently running dirac using my Arcam AV41.
quattro98
Chicago, IL
If I wanted speakers with wider dispersion than KEF, I'd look at Revel. In 2024, looking at speakers with a directivity mismatch between the midrange and tweeter isn't a choice I would make.
Mauro
have you thought about buying vivid Audio Speakers? Check soundstage network measurements! price is prohibitive but also revels f226be are very expensive. You need to like the look of them, though
Robert-Hifi
How was the bass? The previous generation seemed to have a slightly soft low end and not the most impactful/punchy character down low.
Robovox
London
They didn’t strike me as soft in the bass, at least playing electronic music. They won’t reproduce the bottom octave of course but neither will any speaker of this size.
