Fane 15-300TC 15" full range speaker based project
jamescarter1982
To be honest, no
I always listen on axis only
To be honest, no
I had some interesting results making a slotted opening in front of the driver seemed to improve the horizontal dispersion listening just by ear . also the driver took quite a while to break in and really sounded a lot better after it did . got a measurement mic now hoping to do some measurements soon as a friend has given me free reign to design a speaker for him as big as I want. thinking this above a sealed 15ing sub . what percentage would you say the distortion averages above sag 300 htz? I can't see on the graph a percentage number . thanks in advance James
P
ppataki
Budapest
Here you go ;)
eddantes
To be honest, no
Interesting statement.
I was of that opinion for a long time, but now I'm starting to wonder if that's a reasonable position. After all - reflections will arrive to our ears whether we listen to on axis or not. And, if those reflections are significantly different than direct sound - the mix of the two should change things perceptually. However - I am not decided if that's truly audible or not to my (non-magic) ears.
mhardy6647
Horizontal or vertical?
attachment.php
P
ppataki
Budapest
I really would not like to digress, I think there are many-many posts about this subject on this forum; I just would like to say that if you compare the IR curve of a single driver, one-way system with a multiway system you will see that the former will have significantly less reflections.
I practical example that I love: the sliding door to our kitchen is near my left speaker. There is damping material on the side wall next to the speaker but if I open the sliding door to the kitchen the door itself will cover the damping material and will act as a reflective surface. With any previous multi-way systems that action caused a huge distortion in the sound stage due to the reflections that the door introduced. If I perform this experiment with these speakers (or any other single-driver speaker - I have had a few) I hear zero change whatsoever...
jamescarter1982
attachment.php
it was more of a diffraction slit .essentiall close off all but a narrow a slit vertically running the full height of the driver and the sound waves curve outwards from this opening widening dispersion. the narrower the slit the higher in frequencies it has effect apon so to work as high as 20khtz the slit would have to be 17mm wide . mine was 7inch wide and worked very well plan to do more experiments on this now I have a nice and r.e.w
mhardy6647
Gotcha. a la the "Hoodwin" diffraction horn used for decades by EV (and, by extension, Klipsch) in the T35 family of tweeters.
voodooless
Netherlands
just FYI this is a comparison with my previous Nubert nuVero 140 speakers...... (blue is the Nubert)
No comment :)
Those profiles look too much alike to be anything really meaningful:
Here are your 2 graphs overlayed. Beyond 200 Hz they are way too similar. Maybe below 100 Hz it shows some differences.
P
ppataki
Budapest
Finally, the cabinets and the room are now both finished!
Here are a couple of pictures:
And the dimmable, remote-controlled LED lighting is also finished, please see the video here: https://photos.app.goo.gl/QnAjG9jTdgaDzFiu6
So with this, I consider this project to be finished - so far these are the best-sounding front speakers I have ever had or built (I know I say this to all my projects but actually that is the point: to keep getting better and better, right? :))
Stay tuned for the next one! (new one-way rear speakers for the same room using SB20FRPC30-8 drivers)
jamescarter1982
looks really nice what are the lights you've used? what is the rest of your system please ?
P
ppataki
Budapest
Thanks @jamescarter1982
The lights are from a local LED dealer: it consists of 2x50cm white warm COB LED strips, a power supply, a controller and a remote control.
You can find the rest of my system here.
I have moved to full digital amplification (FDA) with two Sabaj A30A in a multichannel system with an RME Digiface USB as a multichannel digital-to-digital converter
I must say I am extremely happy with it and I hope I will be able to stay with the FDA concept from now on
jamescarter1982
thanks some useful info in there. how do you find the bass from these I remebr you were talking about eqing flat into the 20s how does this driver manage with the we in the low end ? Hoping to make a similar pair of speakers for a friend and wonder if subs will be needed or not ? thanks James
P
ppataki
Budapest
I am still fiddling around with the bass but I can already confirm that no subwoofer will be needed, not even for movies (at least to me)
One 15" woofer has the surface area of four 8" woofers, so basically I have an equivalent of eight 8" woofers in my living room now
Response is EQ-d to flat till about 24Hz and the -3dB point is about at 22Hz - and there is plenty of energy too even in that domain
My couch is literally moving below my a$$....just like when I used to have a pair of 12" Dayton Reference subs
And I need to add that bass is superfast, precise (much more so vs my previous systems with subs) and impactful at the same time
Actually I am about to write a separate post about this since I have some bass issues with my room that I just managed to solve without acoustic treatment
P
ppataki
Budapest
