Entreq "signal grounding" Measurements
Sal1950
The Chicago Crusher
Central Fl
in that case persons whatever they bought QAR S-15 are deaf?? At one time alone I didn't believe as well as you, I heard and I believed.
Could I interest you in some Arizona ocean front property?
Fitzcaraldo215
There was a 1927 song in the USA about Prohibition: 50 million Frenchmen can't be wrong. The point was the French drank freely, but we "morally superior" Americans did not, at least not legally.
But, as we well know in this thread, xx million audiophiles can indeed be wrong, unless they use bias-controlled, unsighted, double blind listening. Sighted, uncontrolled listening anecdotes may be good for marketing, but they prove absolutely nothing about sound quality, regardless of nationality or ethnicity.
QAR
on 18 October I am going on the presentation Lukasz Fikus Lampizator , known in the USA.. it will be possible to ask QAR S-15 how he is acting
tomelex
So called Midwest, USA
I have a product to sell to audiophiles, its called belief, and you can take it in pill form.
Speedskater
Cleveland, Ohio USA
On the QAR S-15 test, we only have to read:
'The QAR-14 is a representative of the “new wave”. It is a product labeled as MASS FILTER, as it serves to eliminate high frequency currents flowing through the mass of an audio circuit. It creates virtual (i.e. not connected to the “earth”) mass – an element which absorbs these distortions.'
To say hogwash. Electricity just doesn't work that way.
RayDunzl
Central Scrutinizer
Riverview FL
Blumlein 88
Looks similar to Entreq in that it is connected to the chassis of audio equipment: https://www.qar.com.pl/oferta
It has an RCA cable but I am sure they only use the shield out of that.
With the thinking behind such product I would not be so sure. They might find it necessary to shield the grounding cable. So it doesn't pick up bad vibes on the way to the grounding haven.
QAR
S-15 QAR is built of minerals, block structure. The connection is versatile RCA. the cable cover isn't needed, in such a way that the RCA rope is constructed isn't collecting interferences.
QAR
QAR is second Kondycjonerem of mass which not yet is shown Dynamite, not yet tested in the press, but is arousing the interest in amongst customers. Kondycjoner directly connected to loudspeakers.
QAR
On the Polish market a bit QAR S-15 sold, I want to go the west market up because this Kondycjoner is very good and can compete from far more expensive.
How much does it cost?
And do you use the center pin of RCA for anything or just the outside shield?
QAR
QAR S-15 cost USD 750 + postage. Warranty on S-15 5 of years, 2 years to the wire. RCA wire because he is universal, only mass is interfacing.
