Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,243
- Likes
- 5,483
What didn't you like about their sound?Again, Genelec is not end game for me. But of course I am very happy that it is for others
Get that cardioid up and running and you may not need all that room treatment. And I do not believe the 371 is capable of cardioid down to 60Hz, not flat or -3dB anyway.I am not. As has been said on these forums before Genelec recommends complementary mode for most people.
That front 14” mid woofer just by its dimensions will have controlled dispersion.
I have tried it before and didn’t notice much difference but maybe I can try it again. In my case I wonder how much difference it would make as they are on the 35’ wall far from any side walls and also the room is well treated.
Any issues I have are found below 60Hz anyway and no system that I know of is cardioid below 60Hz.
The D&D 8c is cardioid down to 100Hz. The w371 is down to 60Hz afaik.
I don’t really know how to do the math to figure out how directional a 14” driver is and at what point it goes omnidirectional.
I could try to calibrate in cardiod mode tonight and see if it makes any difference. I think also I’ll bring them in a little closer.
The issue is output will go down in cardioid mode as the 2 drivers will be fighting each other in a sense. Right now they are covering for each other’s deficiencies due to their physical location.
I mean I don’t know. I’m past the tech at this point. I just like how this sound makes me feel. And again many paths to here. I hope you find yours.Get that cardioid up and running and you may not need all that room treatment. And I do not believe the 371 is capable of cardioid down to 60Hz, not flat or -3dB anyway.
That’s easy … Not full range cardioid (roughly flat to 40Hz), near to mid field listening distance, no variable directivity.What didn't you like about their sound?
I mean the treatment ensures less than 200ms decay time. It sounds more impressive than it is to say actually. Just imhoThat’s easy … Not full range cardioid (roughly flat to 40Hz), near to mid field listening distance, no variable directivity.
Well, maybe you can get an even higher level of nirvana with the cardioid … how do you know if you haven’t even tried?I mean I don’t know. I’m past the tech at this point. I just like how this sound makes me feel. And again many paths to here. I hope you find yours.
There are other more important things than cardioid (to me)Well, maybe you can get an even higher level of nirvana with the cardioid … how do you know if you haven’t even tried?
I have once. I calibrated in cardoid once. Okay fine. You’ve twisted my arm haha. I’ll calibrate in cardioid. Let’s see.Well, maybe you can get an even higher level of nirvana with the cardioid … how do you know if you haven’t even tried?
Does it sound better now ?Fine I did it. Haha.
This will take time to figure out.Does it sound better now ?
Who said I won’t have coaxial and reliability? I never did. And have you ever heard 40Hz cardioid before?There are other more important things than cardioid (to me)
Like a coaxial driver, reliability etc
Is that like blacker than black?Well, maybe you can get an even higher level of nirvana with the cardioid … how do you know if you haven’t even tried?
Which one of your finalists have a coaxial driver ?Who said I won’t have coaxial and reliability? I never did. And have you ever heard 40Hz cardioid before?
"End Game" gear for the audiophile is more about the individual's psychology than characteristics of the gear itself. It's less "I found a speaker that allowed me to get off the merry-go-round" and more "I finally allowed MYSELF to get off the merry-go-round."
aha those new dutch & dutch will have coax if that meets the must’ves.Which one of your finalists have a coaxial driver ?
"And have you ever heard 40Hz cardioid before?"-No
I'm 10 for 10 in terms of how my system wowed the last 10 guests.
I never play anything until asked, then when asked, they choose at least the genre if not a specific track.
I don't have a sweet spot, not even any listening chairs. What I do have is probably the clearest, most dynamic, big SPL and bass, they've encountered....about anywhere i would daringly reckon.
Hold on! I thought cardioid meant narrow directivity where the sound is not dispersed evenly but focussed forwards to the listening position to reduce room interactions. I don't believe the W371a is cardioid in the same way the 8c is. This seems to be borne out by the reduced XTC performance of the W371a (in any of its modes) compared to the 8c using BACCH4Mac (around a 5-7dB difference).This will take time to figure out.
Edit: btw it’s called “continuous directivity” mode.
Edit 2: it solved that dip issue. Wow. The graph is better.
Same.
I am curious, @gnarly , (especially with regard to this pursuit of @MKR ): what are the boundaries made of - your 10/10 speaker room - floor/walls/ceiling?
With the same effects achieved, I’m in a room that’s 100% 6” concrete (no windows) excepting the front wall (room-wide, floor to ceiling glass shielded from high frequencies by softwood blinds = effectively invisible to low bass so no real perceptible front wall bounce of low frequencies).
If I had drywall and studs for walls and ceiling instead of solid concrete all around, I cannot imagine things would sound the same. I could surely not get away with such little low end driver SA as I’m using now.
I haven’t found much discussion about how well increased output / SPL of big speakers can make up for structural room boundaries of frequency-selective permeability. Seems like an oft-unaddressed issue simply because most of us cannot go wall/ceiling-shopping or room boundaries-re-engineering as “affordably” as can be done with speakers.
And I’m sorry if querying about house structural composition seems invasive. Just curious about this topic and not intending to pry. Seems at least slightly more relevant a topic in this thread than Genele……….
