Crown Xti4002 Pro Stereo Amplifier Review
Rate this amplifier:
    Votes: 37 21.5%
    Votes: 66 38.4%
    Votes: 51 29.7%
    Votes: 18 10.5%
D
Deleted member 48726
Guest
Since this forum is largely concerned with domestic audio I think it may be interesting to post measurements of a more modestly powered (2x350 watt) Yamaha P3500s: https://www.homecinema-fr.com/forum...mpli-yamaha-p3500s-mise-a-jour-t30056383.html In practice, the fan of this amplifier never came on during the tests. Encouraged by these results I bought a 300 euro 2x250 watt Yamaha P2500s for my son, and here too, in home use the fan never kicks in. Do I need to say that it sounds great (i.e. like any other decent amp)?
I have the P7000s pulling a pair of Infinity Kappa 8.2i's. No noise or nothing. Just an amplified signal.
sebna
I plan to use XTi 4002 to power 2x 18" subs at 4 ohm each (1 per channel). Would it be a good match (for HT)?
Those subs can go to single digits so I guess in this regard it is not but at the same time I should be pretty ok with 4002 being able to do something like 7hz at -1.5db.
What I don't understand is how much power it can deliver at 20hz or lower hz at 4ohm load.
Do I read the review correctly that at 1% THD it can deliver 900W into 4 ohm but at 20hz it drops to 647W and how steeply it drops going lower than 20hz?
Let me know guys what to make out of it.
How bridging it would affect those numbers?
I am also considering XLi3500 / 2500 either bridged or dual channel.
NathanR
FL, USA
Hopefully someone will offer them for testing. I considered buying one myself for testing but even dealer cost is way up there.
FWIW I have via PM. A long list of Pro amps. The older iTech8k is one of them.
We need to clone Amir so we can get more throughput ;)
Note: Amir has not been slacking, the sheer number of reviews going up every week is proof. Too much to test, so little time...
Alice of Old Vincennes
All will work. Imagine strapping one of these on back of self powered sub.
D
Guest
Hi
Hoping for some input on an issue. I know a guy with this amplifier that won't output sound. It turns on and the signal leds react to input signal. Could this be the ribbon cable to the main board from the control panel as some of the other Crowns suffer from? He says he hears relay click..
Spkrdctr
Hi
Troubleshooting over the internet is actually very difficult. We have a few guys on here who have many years repairing audio gear and if they don't respond it means they didn't see your post or it would need to be looked at in person. Try seeing if Crown has any authorized repair centers near you, if not then just go to any audio repair place, they are not that hard to fix. As usual though cost of repair is an issue vs buying a replacement. They were having a 5 year warranty but I don't know its still on. 5 years is very good!
Blaireau
Hello. Honestly, I'm completely dumbstruck by this whole thing. Opinions differ greatly. I want to connect two subwoofers (JBL Stage 1210 4Ω) to a Denon AVR x3500h receiver. Denon would handle crossover, LPF, DSP. So I need a subwoofer amplifier and I was thinking of an XTi 1002 which is only needed for the two subwoofers. The hi-fi system is outdoors, in the yard of my house. I don't listen too loud (about 50% volume) for the sake of the neighbors. I only listen to rock music. Anyone who is a music fan knows that dynamic and accurate bass is very important for rock music. Currently, the JBLs are powered by a home-made 2x100W amplifier (this amplifier does not contain DSP or crossover), but this is not enough power because it always goes at maximum. My question is, is an XTi 1002 suitable for driving subs?
Spkrdctr
Being outside I think you would need a large commercial bass bin powered by at least 2000 watts. doing audio outside is much different than inside. Good Luck!
Blaireau
2000W? JBL Stage 1210 can 250Wrms. I am currently driving it at max 2x100W and it can be listened to. Ok, that's right, I had to boost the AVR rca sub output by +6dB to get the JBL in line with the other speakers on the AVR. That's the problem. I don't want to increase the AVR sub output signal, so I'm looking for a power amplifier for the subs. According to the data sheet, I think the XTi 1002 is OK in terms of performance, and the price category is also appropriate. But I'm not a professional. I don't want to spend unnecessary money, so I'm asking for opinions.
One more thing, the Denon AVR's sub output is RCA, the XTi 1002's input jack is XLR. I read that for good sound you need an RCA - XLR converter box. What do you think about this?
Spkrdctr
You could look at the XLS 2002 as it comes with rca jacks all ready to go. You want an easy to use easy to get going rig. No matter what you buy from Crown it will put out gobs of power. If you are not looking at any computer control (which I think you are not) then I think your only option is the XLS series. It is a very heavy duty line of amps they have made for years. I had one and loved it. Many others on this site have them too especially for sub duty.
Blaireau
You could look at the XLS 2002 as it comes with rca jacks all ready to go. You want an easy to use easy to get going rig. No matter what you buy from Crown it will put out gobs of power. If you are not looking at any computer control (which I think you are not) then I think your only option is the XLS series. It is a very heavy duty line of amps they have made for years. I had on and loved it. Many others on this site have them too especially for sub duty.
I chose the XTi2 series because the fan on the XTi2 can be set to be temperature-dependent.
Spkrdctr
I think you said that you were going to use it outside. If so, fan noise does not matter. If in the house and you push the sub a lot then the fan will come on. But again at that point you may have to 1. Repair the sub or 2. Repair the drywall cracks!!!!;) LOL
Blaireau
That was rough, I don't have drywall. Yes, I use it outside, but not outdoors, but between 3 walls. The amplifier is inside.
Spkrdctr
I think you have all the info you need, now it is just decision time. Good Luck with whatever you do.
dlaloum
I use a pair of XLS2500.... given in my use case they almost never go beyond 4W, the fan never cranks up to become audible.
The fans in the XLS series are definitely thermostatically controlled... and under most common use cases "domestically" only get to their minimum speed...
Blaireau
I understand. So if your amp is unloaded the fan won't run?
dlaloum
Not sure if the fan actually turns off, or just idles at a very low speed where it becomes inaudible.... I think it just drops down to minimum speed, and then ramps up if/when needed (but I am not sure - hard to see in my rack behind cables etc...)
Blaireau
All right. Thanks.
