bluetooth dac - 3.5 mm jack for car [50€?]
germa
Hi everyone
I need advice on a Bluetooth DAC to leave connected to the USB socket (5V) and the audio jack on my car radio.
I would need it to be compatible with the pixel 8's bluetooth codecs (which should support aptx-hd).
The goal is to ensure that the phone connects automatically when I get into the car and start Spotify on the phone.
I don't want to spend a lot because it seems to me that with this app you can stream at most at 320kbit/s so I thought of a budget of €50 (hoping it's enough).
What advice do you give me?
Thank you
ps. sorry for my english I used google translate...
gvl
SoCal
Emotiva BTR-1 looks like it should work for your needs if it’s available in your country. It has digital outputs should you want to add a better separate DAC later.
G
germa
but it doesn't have a 3.5mm jack output, does it?
Thank you
