Beta Test: Multitone Loopback Analyzer software
pkane
pkane
North-East
No,-136db noise for Emu is unreal in any condition,best I have ever managed is -113db in normal conditions.
I think it's Volume control management through windows does something similar with what REW did with the "manual fundamental" setting.
I'm just curious,it's weird!
Probably related to what the ADC is doing with the volume adjustment. Perhaps it's just applying the lower volume level to data after it's digitized.
pkane
pkane
North-East
A preview/test version of Multitone, v1.1.11 is now available: https://app.box.com/s/ue7ll9xmvwogst817x2l1xg09opvgy47
This has a lot of internal changes, and a few enhancements. A lot of code was touched, so lots of testing is needed :)
  • Improved speed of analysis of the waveform
  • Added; a measurement calibration factor (can be used to compensate for gain of an amp or for different dBFS scales between the DAC and ADC)
  • Improved Waveform real-time (oscilloscope) display. Now uses the selected vertical units
  • Improved Spectrum real-time display during averaging, now with updating distortion panel and noise level line
  • Changed: Generated DSD test signal can now contain frequencies higher than 1/2 the base rate
  • Fixed: various small bugs
The calibration factor is in settings window, and can be applied with a calibration file or without. The factor is applied to the captured data before any measurements or analysis:
Sokel
Something is going on with native DSD (DoP is ok).
At the end of the measurement is not like stopping the signal but it's like attenuating it slowly (tested all multipliers,does the same):
Rantapossu
Thanks!
Are you sure that you uploaded the correct version?
There isn't the "Calibration Factor" -selector for me:
The vertical unit is Watts...
....but it doesn't change the Spectrum view:
And I can't find any changes considering the Spectrum real-time display during averaging.
pkane
pkane
North-East
Rantapossu
Thanks!
This is strange!
I reinstalled the orignally uploaded version and now it works correctly.
So it was the correct version after all!
Looks good!
Rantapossu
There seems to be something wrong with the displaying of the vertical units on the Waveform -graph...
... and the Watts -view looks a little bit strange:
The same measurement with dBFS:
Rantapossu
All the dBXX -units seems to default to the exponential notation after the restart of MTA:
Using the mouse wheel to zoom in and out makes the units more human friendly. Could this be the default view?
Entering the values manually directly to the corresponding fields and pressing the Apply!-button seems to do nothing when using the Waveform -view:
This works correctly for example with the Spectrum view, but not here. The "+" and "-" -buttons work correctly however.
Guy.Cohen
Hi Paul,
Many thanks for the new version. I am testing it.
Stupid question: if I want to test external source, like Victor's (Vicnic) oscillator. So, I put external source and push the record button.
The question is: is it possible for the MTA to calculate the THD, THD+N, etc.... I see only peak, RMS.
I guess this has been answered long ago, but currently we have 206 pages to search....
Many thanks,
Guy
Sokel
Hi Paul,
Many thanks,
Guy
Are you sure you have routed the oscillator into your ADC?
I gave it a dirty try with foobar as source and it works fine:
Guy.Cohen
Of course my oscillator is connected to ADC and I see the FFT, and can measure 'by hand', by cursor. There are some parameters written but MTD does not compute THD. Of course it is working with external DAC as source controlled by MTA
Sokel
The above pic is MTA just recording foobar,it does not control it.
The only thing different is that it does not show the progression of averages or the little window animation on top during the measurement,it just shows the measurement after it's done.
Guy.Cohen
The only think different is that it does not show the progression of averages or the little window animation on top during the measurement,it just shows the measurement after it's done.
Maybe I don't understand, you are using a DAC which is played by other software? The MTA only capture?
Sokel
Yes.
I use foobar's (it's a software media player,it's the one on the right side of MTA) output into EMU's ADC.
pkane
pkane
North-East
Remember, Watts are linear units, dBFS is logarithmic (edit: in addition power is proportional to square of V, so what looks like a sinusoid when units are V, looks like a different curve when it's V^2 / R).
pkane
pkane
North-East
Yes, that's a known issue: I simply didn't get to implement that yet (the zoom dialog for waveform window) :)
I'll check why the waveform view dBFS defaults to scientific notation. I thought I fixed that already, but looks like in some initial state it's not working.
pkane
pkane
North-East
For external signal, MTA must pick out one or more fundamentals that your test signal generates, and also distinguish them from any IMD or harmonic distortion that also appears as a possible signal. For this, you need to set the sensitivity level in settings using External Tone Threshold. Set this to a larger number, such as -10dB, for example, which will not consider any of the distortions below -10dB of the peak value as fundamentals:
pkane
pkane
North-East
