LeShog
- Joined
- Feb 19, 2024
- Messages
- 79
- Likes
- 52
Looking at the data gathered from reviews it seems that the best in class is Topping G5, simply transparent. But considered the bluetooth bottleneck I am wondering if more convenient devices (eg smaller, lighter) can achieve the same quality given as a must the bluetooth aac connection. Looking at more practical devices designed to be used on the go the best in class seems to be Fiio BTR7. Still I wonder if it may be an overkill considered the AAC bluetooth bottleneck. Maybe something smaller like Qudelix 5k could achieve the same quality.. So my question is this: are artifacts in dac and amp sections of these devices going to add up to the artifacts of the bluetooth codec AAC or given a better hardware quality (DAC and amp) the only artifacts I am going to hear (if any) are the bluetooth ones?
If we come to the conclusion that artifacts are not adding up, what is the most sensible device to take into consideration without going overkill?
Thank you
Thank you
