Ask help about Pro-Ject Phono box DS2 usb
ooooowl
hello eveyone,I am a novice. I recently encountered a problem. I use a Pro-JECT Phono DS2 usb to rip the record and want to import the phone. and the volume is particularly small, the computer driver can display the device, but it feels like it does not provide a magnifying signal without Phono. Adjusting the gain of Phono, I worry that the sound will be distorted. I replaced the volume of another phono I used before, and the gain of the PROJECT DS2 increased to the CLIP button above 60. Are there any friends who knew this question or also use Project Phono Box DS2 usb ? thanks
DVDdoug
The analog-to-digital converter will clip (distort) at exactly 0dB. Nothing bad happens when you get close to 0dB but it's good practice to leave 3 to 6dB of headroom to allow for unexpected peaks.
Low digital levels are not a problem unless they are super-low (especially if you are recording at 24-bits) so just keep the levels below clipping and boost/normalize later. Pros often record around -12 to -18dB.
I don't have the same hardware and I don't know what that means...
O
ooooowl
Yes, you are right, but I see that the level strength displayed by VinylStudio is left-26. If I turn on the output level of the large Phono and the volume of the computer, the premise is that when the CLIP prompt light will not be on , Can improve the volume that can be heard, but if the computer plays music software at the same time, the volume will be super large, so it feels not normal.
