Anyone make a less than $300 class D with the following capabilities?
CPTX
High pass filter for satellite speakers
Separate low pass sub woofer out
Blue tooth
Headphone out
CPTX
CPTX
Yes, I am flexible on the price….up to $500
This one is close, but no separate sub low pass and no headphone out (suppose you could use the RCA pre out with RCA/headphone adapter)
DVDdoug
You might have to go a little over $300 but you get the most features for your dollar with an AVR. I assume they are all class-D because that's the most practical and economical way to get a few hundred watts.
The standard is a line-level subwoofer out for an active subwoofer with no power amplifier for the sub (which is what I think you are asking for.)
CPTX
CPTX
I have a passive sub…so basically what I have Dayton Audio DTA2.1BT2 plus high pass filter for the satellite speakers would be ideal….yes I have some inline high pass filters…but, I desire the ability to fine tune/modulate.
CPTX
CPTX
^^^Great suggestion…..was trying to accomplish a solution with one purchase…..but I do like the two purchase solution a lot.
Yes, so the DTA-100ST RCA out to something like this:
CPTX
CPTX
I do have a powered subwoofer or two upstairs…I just really like the passive one I already have downstairs for this application…..small…low profile
CPTX
CPTX
An alternative to the DTA-100ST is the $110 RSL 1A255.1. But, the high pass filter is un adjustably set at 90Hz for the RSL and the sub pre out is a plug jack instead of speaker wire binding posts.
CPTX
CPTX
Looks like this solution should work as others have already performed this procedure.
CPTX
CPTX
Of course, nine hours after getting the credit card out; I thought of a single product solution after a night’s rest.
I could have purchased a $165 DSP and DSPd everything so as not to worry about analog filters/crossovers/pass throughs/EQ.
