totti1965
So far I have used the Sonos Connect ZP 100 and was extremely satisfied with the usabilty. Now I want to upgrade the sound a little.
Are there any recommendations from you guys for an inexpensive solution , which includes the following:
1. streamer and DAC (integrated or separate) - at least in the quality of the ALLO Boss 2 streamer.
2. Roon tested or Roon ready
3. MQA -capable, because I mainly want to stream music via Tidal (also in High Resolution).
Does the Allo Boss 2 have a MQA decoder?
Question: Is it the streamer that determines whether MQA files can be played, or is it solely the DAC???
If it is only the DAC that matters, would the S.M.S.L SU-1 plus Raspberry Pi be a good alternative to a Gustard A 26, a Matrix Audio x-Sabre Pro or a Matrix Audio Mini-i Pro 3?
They would be a bit too expensive for me.
Roon is available, so it doesn't matter so much about the ease of use of the device or its app.
