Good morning everyone
Always looking for a definitive pre-line I made some kits with ok but not exciting results
I really like the sound developed in 3 dimensions (which I say 4 because a very good live recording can take you back in time)
Jokes aside... a friend of mine passed me a series type 20k log mechanical attenuator built using Holco resistors
I put it in a box with RCA ins and outs like a passive preamp and connected it in front of an old Bryston 0.4B preamp that I had around and ... my goodness.
By setting the preamp volume to maximum and controlling the level with the attenuator the sound became much clearer and more detailed
The difference between a knife that doesn't cut well and a scalpel
Question... is it autosuggestion or is there an abyss between attenuators and common potentiometers?
Unfortunately it's quite big and doesn't fit inside the case
So I was thinking about a DACT but they aren't cheap
Thanks for any kind advice
