Blind test mode activation
Once two systems have been defined with the “ENTER” and “INPUT” switches, and the volume of the two systems is closely matched, you are ready for blind test mode.
It is important to realize that volume has a tremendous effect on how the brain perceives audio. A system that is slightly louder than another system has a tremendous advantage in being selected as the better sounding system. Take care in matching levels. A sound pressure meter and a white noise generator, used at moderate levels, are recommended for this purpose. However, careful level matching by ear will probably work well for you.
Press “ON-OFF” followed by “1” to enter the blind test mode. The LED’s will go out, the relays will click, and a “1” will be displayed (to indicate test 1), and “blind test” will be displayed.
A random number is “grabbed” when ON-OFF followed by “1” button is pressed to enter blind test mode. That random number is used internally to select either system “ENTER” or system “INPUT” for the 8 tests that are used in the blind test mode. You won’t know the starting system at this time.
The VOL UP/DOWN or CHAN UP/DOWN buttons will either advance or retard the test number. Wrap occurs, so TEST 8 plus VOL UP will go to TEST 1, TEST 8 plus VOL DOWN to test 7.
At each test step, the ABX Comparator either changes to the opposite system, or not, depending upon what it feels like doing to mess with your mind.
You can listen to each test step for as long as you desire.
Make detailed notes of course, labeling your written observations identified with each test step.
Once the 8 tests have been listened to and you decide what you like best (or don’t like) you can reveal which system goes with which test.
To reveal what you were listening to above, press the “MUTE” button to toggle the LED’s back on. You can now step through the tests again, using the VOL UP/DOWN button, and see which system was selected for each test. It should be noted that there is a 1 in 256 chance that all 8 tests will select the ENTER system so no changes will occur throughout the entire test. Likewise there is a 1 in 256 chance that all 8 tests will select the INPUT system.
At any time during blind test the MUTE button will toggle LED’s on/off, you need not wait until the end of the test to reveal what you are listening to. Similarly, at any time during the test, you may press ENTER to change to the ENTER system (A), press INPUT to change to the INPUT system (B), or press “0” to return to the current random test (X). “A” or “B” are displayed in place of the random test number when this occurs
To exit and end this blind test after you have evaluated your results press ON-OFF followed by “0” or simply press the STOP button.
