4.4mm Balanced Line IN - 4.4mm plug to Dual Female XLR cable feasible?
Taltalon
Hi All,
I have a Fiio K9 Pro ESS that has a 4.4mm Balanced IN.
I have an external DAC that also have Balanced XLR OUT connectors. I dont have XLR IN connectors in the Fiio K9 Pro.
Yet there is this 4.4mm Balanced IN thing. I saw on eBay that there are 4.4mm to Dual Female XLR cables.
Is that safe to use? is this too risky? anyone tried something like this?
thanks a lot!
Tal
DVDdoug
That should work.
Jimbob54
Should work fine.
Vincent Kars
Perhaps stating the obvious 4.4 Pentagon is 2x2 plus ground so could not be balanced because balanced like XLR is 3 wires per channel. It probably works the same as going from XLR to RCA.
staticV3
It's balanced. Stereo differential, impedance balanced Line input + safety GND.
You don't need a separate GND for each channel, so five pins are enough.
