LaLaLard
Would the output voltage of a DAC, e.g. 2V vs 4V on the same device, causes different sound signature, apart from the difference in volume?
And of course, assuming both output incurs same level (or just inaudible difference) of noise and distortion.
My impression is most amps would have higher level of THD+N compared to a DAC (assuming both are well designed). In this case is it theoretically better to use 4V output instead of 2V output which requires volume knob on the amp to be turned up a bit more in order to yield the same volume?
