staticV3
- Joined
- Aug 29, 2019
- Messages
- 13,912
- Likes
- 23,864
You might be interested to know that the Meizu Pro has a fantastic ADC inside. It provides 2.7V of phantom power and has a surprisingly clean noise floor. I can test the regular Meizu dongle too, if you'd like.Just want to throw my two cents in on the Ztella. I purchased the non-MQA version. I bought it because it's one of the few DACs that will accept mic/remote input. It sounds great, but I'm sending it back because the microphone input is completely useless. There's barely any signal when used with any of the mics I have. I even tried a powered shotgun mic, that I'd use on my camera. With the +10dB gain enabled on that, it was still very low when I was speaking normally, and had the end of the mic right up to my mouth.
Zorloo's response, after a couple of emails, was "We are sorry that the mic input volume may be a bit low and is the limitation of the chip design. It can only addressed by future silicon update from our supplier."
Because the mic input is essentially useless, I am considering the device faulty. I'll update here if I have any issues with the return. I think I'll try the Meizu DAC instead, as it seems to be even better quality, and is cheaper.
(Apologies for bumping this thread, please let me know if it should have been its own post!)
