Zidoo New Dac
Have had that, plus PEQ for years with MiniDSP HA-DSP, though MiniDSP setup is rather technical, and they left it up to the user to implement the features.
The Luxsin X9 is starting to show up for pre-order in more and more places, and I’m torn between buying it now or waiting for the great @amirm to lay his magical oscilloscope on it. Its spec sheet may look brilliant, but without his bench test, it’s just a promise — a fable without a moral.
New products are entering the market with crossfeed and adjustable soundstage:
Currently I don’t know if this is a hardware or software related feature.
More info probably after HIGH END München 2025
Torben
It's difficult to distinguish between the two today, because a DSP is nothing more than wired software. Since the Luxsin-x9 is said to have a powerful DSP processor integrated, these functions are likely controlled by it.
They say "digital" so that's software/firmware.
You can variably "blend" left & right easily with analog but creating an "immersive" sound is easier to do digitally... Once you have a DSP processor, just about everything is better and easier with software/firmware.
But looking quickly at that link they show regular-old electro-mechanical relays and they say R2R volume control so that's "interesting".
Unfortunately, the term "r2r" for relay-based volume control has become common, especially in China. It's probably obvious why, but I think it's nonsense and creates the wrong associations.
Had mine a few days... It's quite excellent driving the Arya Stealth using one of the Harman curve based HP-EQ profiles. A nicer set of sonic dynamics than the K11 R2R, DX3 Pro+, FiiO K7, NAD D 7050, NAD D 3045 that I had prior. It also looks and feels its price for sure, the volume dial has weight and the ratchet is nice as well as the relays clicking on each increment.
I'm using it via balanced XLR out into TRS in for the Aiyima A80 (an excellent power amp), and 4.4mm out for the Arya.
The screen is also very nice, so smooth and responsive too, all of the functions can be adjusted using the app as well.
I've asked Luxsin to clarify if it's a proper R2R volume controller with relays or if it's just a relay array like on the Topping A70 Pro and just labelled as R2R. Think we know what the answer is anyway...
Update direct for Luxsin, the R2R volume control does contain resistors:
The X9 features a true balanced differential circuit composed of 20 Omron micro relays and 88 precision metal film wafer resistors. This design not only ensures complete left-right channel symmetry but also effectively reduces crosstalk and impedance in the signal path. The use of metal film resistors ensures highly consistent resistance values and long-term stability, avoiding any negative impact on sound quality due to thermal drift or component variation.
The system offers up to 1024 discrete volume steps, each providing exceptionally fine granularity for near-imperceptible and smooth volume transitions. Compared to traditional digital attenuators, this analog control method delivers superior sonic transparency and dynamic performance.
Of course it does. But it has nothing to do with weighted R-2R networks.
I should be getting the Ferrum WANDLA in for comparison in June so am looking forward to that comparison as the WANDLA is like 3x the price.
Forgot to share my subjective but in-depth review!
You have probably come to the wrong place. We don't do that here.
We do, just not the focus.
