The infinite list ...The human ear
The perfect loudspeaker
The perfect recording
How's your python? https://github.com/markbergsma/genlc looks like it would provide the communication with the GLM USB adapter.2. An app - and if necessary a signal-converter dongle - that allows one to replace the Genelec 9101 wireless remote control with one's smartphone. if that's not feasible, then a successor to the 9101 that adds a display of what the actual f***ing GLM volume level is, better buttons, and momentary LEDs to confirm your button press has actually changed the volume by one step or has actually turned the system on or off.
Continued in a separate thread:I agree. MC into a good interface and digital RIAA is far better than anything else I’ve heard.
Also allows room correction on vinyl, which is for me now a basic system requirement.
Will never go back to an analogue phono pre.
Looking forward to your measurements.
www.audiosciencereview.com
Great idea for a topic. Here’s one that has been in my head for a while: a digital-to-digital converter that accepts spdif data and outputs USB.Ok, first, this post comes with a heavy first world problem warning…
And am I alone?
Note: The devices below are for USB input into a computer (host), not to a DAC (receiver). The WiiM Amp and WiiM Ultra will have the ability to do S/PDIF (optical) input to a USB receiver such as a DAC.Great idea for a topic. Here’s one that has been in my head for a while: a digital-to-digital converter that accepts spdif data and outputs USB.
hifimediy.com
hifimediy.com
Intriguing suggestion, many thanks! I notice this in the description: Please note that it can’t be connected directly to a USB device like a DAC, it must be connected to a USB host like a computer. That appears to rule it out for the use case I had in mind.Hifime UR23 SPDIF Optical to USB converter. Also available on Amazon for about $10 more than ordering direct from Hifime.
Hifime SPDIF Optical to USB converter, record DAT/minidisc to computer
The UR23 accepts SPDIF optical sources and transfer this to USB. Suitable to record DAT tapes, minidisc or other digital source to a computer.hifimediy.com
Invisibility paint to hide speakers. Better yet, ideal point source speaker without physical matter![]()
Microphone preamp instead of phono preamp
Hi all, I was inspired in another thread to compare performance of my RME UFX II mic input vs. my ProJect DS3 B phono preamp. Setup is as follows: - Technics SL1210GR with AT 33 PTG II MC cartridge - Balanced wiring between MC cartridge and preamp - RME ADI 2 Pro is used as control unit and...www.audiosciencereview.com
I like your thread and often feel the same way. I'm even inclined to think they keep things separate on purpose to sell more boxes.Ok, first, this post comes with a heavy first world problem warning.
But...
Am I alone in feeling I have to compromise, and also sort of feeling that I shouldn't?
My system situation is almost catered for by what’s on the market but not quite (unless I spend frankly ridiculous £££).
Maybe I'm deluded, but I feel my audio needs are fairly typical for today's invested music lover (no 'a' word please). Two channels, streaming, a few records, a digital source, room correction.
And yet I still have to faff around with an inelegant cludge of boxes, routing, software, and cabling to get the usability and sound I want (which is, let's be honest and thanks in no small part to ASR, fabulous.)
So I thought I’d start this thread to find out if you out there are fully satisfied. And if not, to create a place to share what would make it so (in vain hope clever industry people will take pity and create our desired wonder boxes).
My perfect component would be a one-box preamp/DAC that has the following (and doesn't cost £35,000 - yes very funny Linn).
Several components come really close to doing all this at a reasonable price - RME, MiniDSP, Eversolo I applaud you. But each one lacks at least one vital element.
- DAC with USB, optical and coaxial digital ins
- Analogue preamp with enough gain for low output MC cartridges
- ADC
- DSP on all inputs (including analogue - Eversolo, why???)
- Digital RIAA EQ
- Parametric EQ - at least 10 bands per channel
- Or better still a convolver with tens of thousands of taps
- Dynamic loudness (why does only RME do this for two channel... it's brilliant)
- Roon-ready network streamer
- Bluetooth
- AirPlay
- Balanced analogue ins and outs
- Great measurements across the board (obvs)
Have I missed something? If not, would someone kindly create it?
And am I alone?
