Your latest cool purchase
People are sharpening knives that cost tens of dollars. Tens of dollars only. They can't be expected to invest multiple hundreds of dollars or even thousands of dollars for, "Shaving Sharp." You are invested in the fantasy at this time and now are dictating to me and the masses.
100% disagree.
Using a $40 Forschner chef knife to break down 20 lbs of veg or $35 Forschner Butcher knife to break down a 25lb brisket - good luck with your method unless you're resharpening every 5 minutes.
Yes. I do have $300+ Japanese zdp, Super Blue and VG10 knives but when I do my sharpening routine, all of my knives get the treatment. Only difference is fewer stones used and no final polishing including my Forschners.
BTW, where do you calculate the thousands of dollars? 3 good stones is a couple hundred bucks. Diamond flattening plate another 60. Those wedges are 15. That's about the same price as a decent electric sharpener that Cooks Illustrated or Wired generally recommend.
Pity you if you're doing anything more than cutting some celery, lemons or zucchini. Even cutting a couple onions is torture without a properly sharpened knife. If that's fantasy, then I'm happy to stay in that world and not be miserable when I'm cooking.
Check these out from the ASR Knife thread..inexpensive but probably used by a wholly unscientifically vetted number of Asian culinary amateurs and experts. Can't wait to get mine. Peace.
100% disagree.
Yes. I do have $300+ Japanese zdp, Super Blue and VG10 knives but when I do my sharpening routine, all of my knives get the treatment. Only difference is fewer stones used and no final polishing.
You can disagree all you want but that does not make what you say sensible, reality or factual.
You said>>>
"Once you get the hang of these, knife sharpening becomes very straightforward as long as you have a few water stones.
Over the years I've bought the 100, 200, 400, 800, 1500, 3000, 8000 grit Shaptons which are my favorite.
Then you need the diamond flattening stone which is a must.
But using the wedges, gets you the edge and the angle that you want. Also, if you have one-sided or right/left knives, the wedges also solve that problem."
So.. According to you for a simple knife of only tens of dollars expense a person needs these grit of Shaptons sharpening stones which cost in Canada from $70 each to $126 for each stone. I am going to go out on a limb and estimate the 7 stones to cost ~$490 to $800 Canadian for the set of 7 stones.
100
200
400
800
1500
3000
8000
Then a diamond flatting stone is a, "Must." How much is that in $$$?
Plus the wedges are required because all of this system is very complex, technical, requires time and energy to learn to use it and understand it etc.
You are not making good common sense.
You apparently are in the fantasy of the knife shaving sharpening shaving sharp rabbit hole and now are attempting to dictate to me and all here about the only way to sharpen a edge and you are assuming a stance of authority here on knife sharpening.
I bought the Henkel's 8 inch chefs knife for only $70 and I bought the carbide knife sharpener for $30 Canadian dollars. I stroked the blade 8 times through the carbide edges and now the chef's knife sails right through all veggies, meat and a cardboard box now with no real effort required.
Beautiful knives for sure. I worked a Chinese restaurant for years and they always used a lot of knives and cleavers.
I'm still awaiting your explanation why you tossed slag at me for stating facts.
Hi Doodski,
There's no point in arguing on the internet or waiting for explanations that won't come.
Let's talk about something more pleasant.
I think that even very cheap knives can be sharpened very well if they are not made of stainless steel.
I was given a Horl sharpener, which I get along with quite well, although I do my daily sharpening with a ceramic whetstone.
Horl sharpeners are now available as copies from many companies in Europe and, very cheaply, from China.
Since I enjoy cooking, I also have a few knives, and my latest purchase was this knife holder, which I placed right next to the hob.
A few of the knives I use most often, including the ceramic whetstone
The knife with arguably the most beautiful handle and blade, but it's not just for show—it fits comfortably in the hand and can be sharpened to a very fine edge.
For large pieces of meat with bones, I use the left one.
A blade made of four types of metal in Damascus steel
I wish everyone a good time and little trouble, whether on the internet or in the real world.
Why would you tell me there is no point in me doing something? Seriously? That seems good to you? If I want to point out something that somebody states to me that is fiction stated as a fact and is spin I will do that. Your agenda and schemes are not my agenda. I don't appreciate you belittling me by denigrating my commentary based on your assumed moral high ground and propping that up on a guess and assumption.
I am waiting for an explanation? Where did you see that and when did you come to that realization? Did you use a crystal ball to envision what I think and what I was anticipating? A crystal ball has about as much accuracy as assuming and guessing. That comment was about maneuvering and had nothing to do with anticipating and waiting for a response. But you are apparently confident in your belief that you know it all and that you know best and come at me like an authority.
The S.M.S.L B100 bluetooth reciever. Got this at a black week discount. Probably totally overkill for a bluetooth reciever, but I like the stationary design and full connectivity. A cool purchase I think..
Since outside of the main audio forum, do not give this thread the same scrutiny, but getting too many reports to ignore so have closed for some cooling off.
Some have received warnings and seems a reminder to focus on the topic is in order. Thanks!
After some cleanup of off topic and member spats, thread is open again.
Happy Holidays!
Received yesterday one of my all-time favorite albums on blue-ray remastered by James Guthrie in high-rez in stereo and all forms of surround sound
I will listen to it tonight in the manner befitting such a wonderful work of art (if I can wait that long)
Something came through from my aunt in Nova Scotia for my Xmas :D, 14g of pleasant sativa which I’m diving into to right now, it’s not the usual strong stuff but more of an anytime helper smoke/vape at only 7mg THC per gram,
Should help with my incredibly tight muscle spasms, SPMS is a bloody drag 24/7 and so tiresome, of all the neurological conditions you can develop I guess my immune system really fkin hates me, i really hit the jackpot with this one :facepalm:
Since I saw some Leo Bodnar gear somewhere else on the forum. I treated my homelab (and everything else connected to that network) with.. a clock. It lives in a hip 10" Rack. Also mapped all the usual default ntp servers to its ip dns wise.
I will properly medicate tonight with some similar product before auditioning my new Pink Floyd blue ray tonight, but for different reasons
My wife suffers some similar ailments so I sympathize completely with your situation and wish you the best of luck
Just scored an Airrobo P20, €89.99 from Darty. Very basic functioning 'Roomba' but doing a great job of picking up after us all. So long as its intelligence doesn't evolve and it turns on its human masters and destroys us, I'm winning here :D
