Your latest cool purchase
A semi-automatic knife sharpener that actually doesn't ruin knives.
What a rabbit hole that entire knife sharpening business is. WoW! I spent days in that rabbit hole. I bought multiple sharpeners and all junk and tossed my money into the pit of the sharpening business. The worst was the 2 different and from totally different sources diamond hone sharpeners for $40 each. They had them locked in fancy glass display cases at the retailers and made a big deal of them and I actually was made to feel as if this was special, high value, diamonds and the store clerk was really going out of his way opening the glass display case with his huge keychain to get me a diamond stone/hone thingy. I got home and was excited to finally get my chef's knife that came out of the wrapping sharp enough for nothing. They shaped the edge but it was not sharp and could not cut romaine lettuce well never mind a tomato or a cardboard box as a 8" chefs knife should have no issue with. I immediately set upon the task and opened the diamond hones/stones each time I bought one. The result is that I kept trying to get the knife sharp and the more I tried the less it was occurring. the diamonds on each hone/stone thingy had fallen off due to the adhesive failing and after the ~8th pass of the stone over the blade there was no more diamonds to speak of. Then... The retailers both... Treated the situation again like they are diamonds and this is a very special circumstance and no warranty and no returns and blah blah. It was absurd. Total hogwash and I knew it but they kept pretending and shoving the agenda so I decided no more money for you forever from me and I went back to Amazon. So I researched and researched, video after video and read and read. All the fancy various totally different systems and reviewers with various tests and blah blah. So... I decided it can't be plugged into the wall, can't require training and leaning to operate the "system", can't be a diamond hone/stone and it needed to be very easy to operate with no learning curve. So I bought a $30 SHARPAL 104N 5-in-1 Professional Knife & Scissors Sharpener. It took the chef's knife and in the first 3 passes across the "Standard" cutters it literally cut the edge from the blade and metal cuttings where on the countertop from the cutting edges of the knife sharpener. After 8 passes with no learning curve and no training myself to be able to do it I was cutting veggies like warm butter. I tested the chef's knife blade on a cardboard box and never sawed it but pushed the blade and it cut right through cleanly. All those other sharpeners instantly became garbage, wasted money, absurd snake oil and I was finally happy I had a real life knife sharpener.
Looks fantastic, a proper vintage icon
Thanks!
To correct a brain fart in my prior post - this car is actually a TF (with the 1250cc "XPAG" engine), not the later TF-1500 (with the upgraded 1466cc "XPEG" engine). For some reason, a previous owner stuck a pair of TF-1500 badges on it.
Only about 9600 TFs were made in total (all flavors), which really is bugger all when you think about it. North of 100k MGAs were made. MGB production was north of 500k.
What a rabbit hole that entire knife sharpening business is. WoW! I spent days in that rabbit hole. I bought multiple sharpeners and all junk and tossed my money into the pit of the sharpening business. The worst was the 2 different and from totally different sourced diamond hone sharpeners for $40 each. They had them locked in fancy glass display cases at the retailers and made a big deal of them and I actually was made to feel as if this was special, high value, diamonds and the store clerk was really going out of his way opening the glass display case with his huge keychain to get me a diamond stone/hone thingy. I got home and was excited to finally get my chef's knife that came out of the wrapping sharp enough for nothing. They shaped the edge but it was not sharp and could not cut romaine lettuce well never mind a tomato or a cardboard box as a 8" chefs knife should have no issue with. I immediately set upon the task and opened the diamond hones/stones each time I bought one. The result is that I kept trying to get the knife sharp and the more I tried the less it was occurring. the diamonds on each hone/stone thingy had fallen off due to the adhesive failing and after the ~8th pass of the stone over the blade there was no more diamonds to speak of. Then... The retailers both... Treated the situation again like they are diamonds and this is a very special circumstance and no warranty and no returns and blah blah. It was absurd. Total hogwash and I knew it but they kept pretending and shoving the agenda so I decided no more money for you forever from me and I went back to Amazon. So I researched and researched, video after video and read and read. All the fancy various totally different systems and reviewers with various tests and blah blah. So... I decided it can't be plugged into the wall, can't require training and leaning to operate the "system", can't be a diamond hone/stone and it needed to be very easy to operate with no learning curve. So I bought a $30 SHARPAL 104N 5-in-1 Professional Knife & Scissors Sharpener. It took the chef's knife and in the first 3 passes across the "Standard" cutters it literally cut the edge from the blade and metal cuttings where on the countertop from the cutting edges of the knife sharpener. After 8 passes with no learning curve and no training myself to be able to do it I was cutting veggies like warm butter. I tested the chef's knife blade on a cardboard box and never sawed it but pushed the blade and it cut right through cleanly. All those other sharpeners instantly became garbage, wasted money, absurd snake oil and In was finally happy I had a real life knife sharpener.
Horl have some simple but ingenious solution for the knife nerds. Not my piece of cake, but I admire their approach:
Yes, I was geeking out on that design too. It is for sure intriguing and they really went out of the box into ingenious simplicity.
Arrived on the door this evening:
Good evening chaps! This 1954 MG TF-1500 roadster.
It wasn't really made to accommodate my 184cm height, but being slim and unusually flexible, I can fit - just. Feels like a real death trap too - so in a couple of words, freaking awesome!
I'm not much of a fan of the model MGA that came after this or any model younger. These TFs have a much, much better "vintage" look and feel to them, IMO. They didn't make too many of these TFs and the going prices have been trending quite upwards in recent years, so I decided to grab one.
Dear Mods,
Please close this thread. @GK. has officially won.
Very nice, they are surprisingly very nice to drive and can certainly hustle on once you get accustomed to their quirks. Below is my mates very early MG prototype (1 of 5?) made by the factory to test the concept, this one was driven to many championships by one of the first female race drivers and my mate has reams of paperwork to fully back up the history and provenance of the car and the race wins.
I agree on the MG.
I had the chance to buy a ?1952? TD just before I left for college - $900, in running, driving condition, and I let myself be talked out of it.
Sure, that was 50 years ago, but I always thought that was a big mistake.
I did later own a TR4A and MGB, (and 914/6) and ran them both nearly into the dirt with joy and fun.
I recall the many cross country trips I made in them, and now, when I see one, and am reminded of how tiny they are, I'm amazed I survived all those truck dense interstates - barely suitable as hood ornaments for most big trucks!
And to think I even considered the Triumph Spitfire as 'too small to be safe', at the time!
Lie Nielsen 10 1/4 bench rabbet plane. A remake of an old Stanley plane. Everything is beefed up, thicker blade, better iron cast etc. Knob and handle are tiltable to the sides. Between blade and knob there is a screw(front right). It holds a knife you can extract to cut through cross grain. US made. Im not really sure if im gonna put it to use or place it in a downlit bookshelf :D
Made in small series. I could actually make money from reselling it. Isnt that nice? Not going nowhere though.
Doodski,
I’ve spent some time in that rabbit hole as well and never was that pleased with my results.
You’ve convinced me to try the Sharpal. For $20, I’m willing to take a chance.
Doodski,
I hope it all is good for you. The absurdity of the knife sharpener rabbit hole is as I saw primarily oriented around, "Shaving Sharp." The legend, spin and resulting fantasy around getting it shaving sharp. I have had many assorted knives. I have butchered many many chickens, geese, ducks, turkeys, pigs, cows, heifers, steer etc and all the shaving sharp stuff is at the point of diminishing returns and the shaving sharp only lasts a very short while dependent on what the material is being cut. I gave up on shaving sharp when butchering pigs and the objective is to get rid of the coarse hairs so that the skin can be used for a rind when frying it. The method of shaving sharp was every time all the time a waste of my time and energy over and over. The final method used was the torch and simply burn it off. Shaving sharp is for facial hair and very thin very specific metal alloys and not for hand held knives.
My $0.02
My 15 year search for simplicity in knife sharpening was solved by these plastic wedges.
https://www.amazon.com/Wedgek-Angle...phy=79531&hvtargid=pla-4584482464076496&psc=1
knife sharpening wedge
Once you get the hang of these, knife sharpening becomes very straightforward as long as you have a few water stones.
Over the years I've bought the 100, 200, 400, 800, 1500, 3000, 8000 grit Shaptons which are my favorite.
Then you need the diamond flattening stone which is a must.
But using the wedges, gets you the edge and the angle that you want. Also, if you have one-sided or right/left knives, the wedges also solve that problem.
Having tried almost all of the OTC knife sharpening gadgets, at best, they're good for touch ups. At worst, they damage your knife edge and you have to then spend lots of time to repair them or send them to a professional knife sharpener and have them do it. Big down side is the significant loss of metal in re-edging the blade.
I hate to rain on your parade, but the only way to sharpen a knife is with a stone running perpendicular to the blade
Sharpening parallel to the blade will never achieve a truly sharp edge that will last thru more than a few uses
I know it sucks, but it's the nature of the beast
Not fact. I sharpened a knife using a carbide cutter in 8 strokes. I have been sharpening knives for many decades and there is not a singular method as you dictated to me is the only way. All fiction and not fact on your part.
My $0.02
People are sharpening knives that cost tens of dollars. Tens of dollars only. They can't be expected to invest multiple hundreds of dollars or even thousands of dollars for, "Shaving Sharp." You are invested in the fantasy at this time and now are dictating to me and the masses.
35 years years ago I handed my Gerber pocket knife to a guy at a booth at woodworking trade show and after watching him cut through some paper and straw and rope with my knife, I handed him the the $35 to get this. I have sharpened my wife's high end Mac knifes. tons of tools, scissors, dikes, nail clippers... all to perfection. Once after running out, I used a single utility blade to drywall a whole room sharpening when dull for 30 seconds each time. For flat chisels and hand planes I use progressively fine sandpaper, a flat piece of glass from an old wall clock face and an multi-angle roller guide that keeps the edge perpendicular to the surface.
It still is going strong cleaning the the triangles stones with powdered sink cleanser.
