I use loudness correction daily by cranking up the volume.
@Hayabusa What is the source of these measurements?Indeed, not very clear what deltas, they are also off it seems.
These are the deltas measured from Audyssey wrt to the 85dB reference level for different volume offsets:
How did you derive these curves? According to the differences (deltas) in equal loudness contours, the compensation should be mainly on the bass response---also see the study I posted above as well as @solderdude's compensation curves (also Audyssey 's delta curves posted by @Hayabusa).
For one, the equal loudness contours, that are the basis for compensation, are specified only up to 12.5kHz and need to be estimated above that.
Perhaps I am preaching to the choir here, but calibrated loudness correction has been one of the easiest and most worthwhile upgrades to my listening setup in years.
It is widely known the human ear is not even close to "flat," but further complicating this is the degree to which it is not flat changes with volume. An implication of this is that all content is mixed for a certain volume level, and listening above or below this level will change the tonality of the content. The low-bass region is the most impacted.
But if we know this, and know how loud our headphones (or speakers) are playing, we can correct for it.
My tools of choice are a UMIK-1 (with miniDSP provided calibration file), REW, and EqualizerAPO.
EqualizerAPO provides "Advanced filter"->"Loudness correction" which relies on leaving the hardware volume knob to a set point and then using the operating system volume control after calibration. During calibration, I used REW's SPL meter and maxed out my Fosi DS2 gain to achieve about 70dBC on the calibration tone.
When active, this is how it looks during typical playback.
If you are already familiar with EQ software like EqualizerAPO, you might already have an EQ profile loaded. I did too, and my immediate reaction was too much bass. I have suspected for some time the subjective preference for a bass boost is to serve as pseudo-loudness correction - thus with actual loudness correction applied, you will likely want to adjust your previous EQ profile. I turned my bass down 3 dB, on a profile I loaded from AutoEQ.
I am not very familiar with other EQ suites and platforms, and how to achieve loudness correction with them. My hope is this thread can become a good resource for knowledge sharing around this.
What is definitely clear is that this is a marked improvement over listening without loudness correction. In a reasonably quiet home environment I had no reason to listen to content at the 80dB or more it is often mixed to, and this allows me to enjoy the intended tonality at a more comfortable and considerate volume.
www.audiosciencereview.com
It appears that the Eversolo loudness FIR filter mimics the equal-loudness contour of the human hearing system.
