wadude
The main reason I listen through speakers is that the sound changes based on many variables, not just loud and soft. It seems closer to the real thing.
There's not much loss with lower volume in the higher frequency part of the contours, so perhaps one only needs to use their bass control?
Thanks. Where is that from? I'm not finding it enlightening.
Indeed, not very clear what deltas, they are also off it seems.Thanks. Where is that from? I'm not finding it enlightening.
These are the deltas measured from Audyssey wrt to the 85dB reference level for different volume offsets:
filters:
loudness:
type: Loudness
parameters:
fader: Main (*)
reference_level: -5.0
high_boost: 10.0 (*)
low_boost: 4.0 (*)
attenuate_mid: false (*)
This example makes quite big corrections not really inline with equal loudness deltas I would say....Thanks, that's more helpful. Camilladsp has a loudness filter with a magnitude response that looks like this example:
But it does allow you to set separate low and high boosts, they do not have to be the same:
YAML:filters: loudness: type: Loudness parameters: fader: Main (*) reference_level: -5.0 high_boost: 10.0 (*) low_boost: 4.0 (*) attenuate_mid: false (*)
More here: https://github.com/HEnquist/camilladsp?tab=readme-ov-file#loudness
Camilladsp also has a compressor, but that has a lot of parameters to adjust.
GitHub - HEnquist/camilladsp: A flexible cross-platform IIR and FIR engine for crossovers, room correction etc.
A flexible cross-platform IIR and FIR engine for crossovers, room correction etc. - HEnquist/camilladspgithub.com
That example is set up for explaining how the loudness filter works. The corrections are too large on purpose, because that way it gets easier to see what happens in the figure.This example makes quite big corrections not really inline with equal loudness deltas I would say....
Room for improvement there.
It's only potentially 'correct' for a limited number of movies made in the last decade or two and there are still way too many unknown variables for it to make any meaningful difference. And what if I simply prefer less bass than the producer did?
Says who? That's a very dubious claim that movies are 'meant' to be listened to 15 dB louder than music.
For me, any recording (whether movie or music or anything else) is essentially a black box of which we can know nothing with regard to the loudness, tonal balance, spatial chracteristics etc. of the recording situation. Likewise, it's utterly pointless to try and second guess the 'intent' of the artist/producer. All we have is the recording as it stands and the reality of our listening environment which we can then tweak so the subjective experience is as pleasing as possible for the widest variety of material. By all means use automated loudness correction if you feel it adds value to your experience, but don't imagine that it's in any way more accurate or 'correct' than manually adjusting tone controls to taste ...
So if one is in the Mac world, is there an easy way to test out if using loudness compensation is for me? I’m running Sequoia and have Sound Source.
How about A Hairdryer by The Smile?give me a random song you love and know well and I create a small presentation. should have bass though
This is what I hear. Not the fletcher munson or equal loudness curves, both highly exaggerated in my opinionIndeed, not very clear what deltas, they are also off it seems.
These deltas are still an (almost) direct conversion from the equal loudness curves.This is what I hear. Not the fletcher munson or equal loudness curves, both highly exaggerated in my opinion
How did you derive these curves? According to the differences (deltas) in equal loudness contours, the compensation should be mainly on the bass response---also see the study I posted above as well as @solderdude's compensation curves (also Audyssey 's delta curves posted by @Hayabusa).
