RandomEar
- Joined
- Feb 14, 2022
- Messages
- 1,455
- Likes
- 3,841
I have found three examples [1, 2, 3] of forum members using DeltaWave to "null out" DACs against either the source file, others DACs, or the DAC itself. From what I can see in these examples, the DACs mostly differ due to different reconstruction filters.Your writing is one of the most impressive text I read recently on the subject. . I would love to continue the communication on the testing part knowing that I am not into this area as a profession. The last experiment seems interesting because if we are able to go analog and back to digital and produce the same PCM data points in the original file, this will be an end game. So, I would appreciate if you share more highlights on that experience it will be great. I am sure the results will show some errors worth investigating.
For reference: It appears that the limit for the "PK metric" error calculated by DeltaWave for DACs against themselves is around -100 dB. It probably also depends on the ADC in use. Nonetheless, anything close to that (probably below -95 dB) is essentially "perfect". Anything above -50 dB can be considered "potentially audible".
We certainly are the biggest sources of biasI own some equipment like Chord Dave + Mscaler, Chord Hugo 1, Topping D900 and Fiio K17 AND k11 R2R. Each of those DACs sound different and it is easy for me to spot that with some accuracy. The difference is clearer when I use my Focal Utopia or speakers. When using a planner magnetic headphones the differences are trimmed. So, this is about subjective listening. As a scientist I prefer to take myself outside the equation as we people are perhaps the biggest sources of bias.
A "slow" reconstruction filter is certainly the easiest way you can create potentially audible differences in DACs, mainly due to the drooping FR in the treble region. I still don't see the absolute need to spend 1000 $, but that's also not an outrageous amount of money. So there's little point in preventing people from "wasting" their cash. At 10k or 100k, yeah - that's SCAM-level.Eventhough there are differences, however the music is basically also very similar except the R2R which does some coloring. The rest are very close. It seems as you mentioned it is to do more about digital filtration. And hence we bring them closer when we use external digital upsampling and filters. I conclude that a $1000 is sweet spot to buy a good DAC. Spending more is a personal choice but it will not be about batter sound but a preference. Those who put $100k on MSB DAC is a soft scam. I heard one and it sounds worse than all good R2R DACs in the 2 to 5K range.
