You can keep only one component from your system - what would it be?
In my hi-fi life, I have probably replaced every component several times, although I haven't always sold the old ones, so some of the devices are here in multiple Variations.
What I would probably miss most is the hassle-free streaming via WiFi in the multiroom version and control via smartphone.
I got used to this very quickly and find it very convenient to be able to select any music in high resolution from every corner of the house and control the volume with my smartphone in my hand.
That's what I would probably miss the most.
However, this requires multiple equipment, so your actual question is very difficult for me to answer.
Let me try: A smartphone with Bluetooth headphones, if you count it as hi-fi equipment.
Along that line of thought, a brain is more difficult to replace than ears.
"Abby someone..."
I'll go the other way, not my best component but my only turntable, a VPI HW19 with Rega arm because I need something to play my record collection which I hardly do. I do not need or covet a different or better one so it will stay and answer when called upon to play a rare nugget not on streaming or in my 1200 recordings in my NAS.
Well that's a pretty nice tt and a venerable arm. Would the cartridge be on your list for that sine qua non 'component', too? ;)
(actually, it's a semi-serious, if distressingly tangential question...)
Well probably not. I used to have Ortofon 2m Bronze but traded that for another Nakamichi 620 power amp and a 2M Blue, my current and most likely last cartridge. I am currently refurbishing a 1977 Nakamichi System One and plan on keeping that until I get an offer I can't refuse.
Until recently I would have said my amplifier, but that broke, so now I would say my record player.
I realise that in both cases I am just choosing the most expensive component in the system, so I guess my rationale is purely pragmatic and not based on any emotional attachment.
What I've discovered and what is quite liberating is that there is no component in a system that is irreplaceable, so long as your criteria is about reproducing music and not an attachment to e.g. your Dad's Nakamichi Dragon, which is a different case.
My Hypex NC400's, everything else has clear upgrade paths that would provide an audible difference.
As I’m contemplating retirement, and the possible shedding of gear at some point, I started to wonder what I could live with in terms of my system and what I could sell.
It brought to mind the question that is sort of an offshoot of this:
If your system was going to be taken away, but you got to keep one single component, from which you can move on and rebuild your system with different components, which component would you keep?
I guess it might be a version of “ what is your most cherished component in your system that you feel you could not do without?”
For me what sprung to mind is that I would choose to keep my Conrad Johnson Premier 12 tube mono amps.
They’ve been the most consistent factor in my system, as I’ve had them for something like 25 years now, powering all sorts of floor standing speakers, through periods where those were sold and I only had more modest stand mounts, and then back up to more expensive floor standers again when I could afford them.
It didn’t matter which speakers I had hooked up, every system truly sang to me with the CJs.
At this point, I don’t care whether it’s how they actually sound, or whether it’s a partial bias effect or entirely a bias effect. It does the job for me and I would want those on the end of any speaker I would use next.
How about you folks?
(I suspect I would get some slightly different answers here versus other audiophile forums, which is partially why I am curious).
This is an interesting question! For me, I think the answer most in the spirit of your question would be my Genelec 8351b's. My current system is just them, a Mac mini as a local music server, a Sony disc transport that I hardly use anymore (because all my discs are ripped and the mini is so convenient) and an SMSL digital converter box to get from the mini to the Genelecs.
However, with that said, I'd also like to comment on that final parenthetical remark in your post: that answers here might be different than those in other audiophile forums.
I agree with you there, and in my case my experience at ASR over the years has made me less attached to any particular piece of gear - not because I don't love and value my gear, but rather because ASR has taught me that the idea of a truly unique-sounding stereo component that produces some kind of synergistic "magic" that I could never replicate with other gear is a myth, and a myth in two different ways: (1) most of the time it's possible to get more or less identical sound with different gear if the gear measures sufficiently well and is set up properly; and (2) even when there are subtle differences, as there will always be with even the best speakers, there's a level of perceived quality beyond which differences are discernible but (at least for me) do not necessarily register as clearly better or worse; they're just subtly different versions of "awesome."
So I do prize my 8351b's, and I love how they sound. But honestly, the reason I wouldn't want to get rid of them if I couldn't replace them with another pair of the exact same model is simply because the other models that would be "no-brainer, I'm 100% sure these will be just as good or better" choices for me are more expensive: basically the 8361a and the Dutch & Dutch 8c.
The MoFi Sourcepoint floorstanders might be just as good or better, but then there'd be the hassle of adding a power amp and MiniDSP or similar component back into my system for room correction, and I've gotten spoiled by the Genelecs being basically an entire system unto themselves. The KEF LS60 might be just as good too, but I've never been a huge fan of KEF's software and I'm not convinced they'd give me quite all of what I get with the Genelecs (although maybe they'd give me more, who knows). You get the idea.
The one component would be the Floyd Toole book Sound Reproduction. I just got it and I wish I had gotten it twenty years ago. In truth, the one component I'll keep are the Revel speakers but when I get old, and I am quite near that now, and have to move into a smaller place I will keep the much smaller Neumann speakers.
I would unfortunately keep not one but two.
A nice DMM and a decent audio interface.
Using a music streaming service, I have not found a way to backup downloaded music (without paying for a second subscription). If the service loses all your downloads, customer support instructs that redownloading your thousands of songs one at a time is the solution. That has to be the most difficult component to replace.
Downloading? Streaming means you don't have to download anything, right?
(I might be confused, as I only use Roon, which just helps manage my own files that I keep in redundant cloud storage and could easily also backup in physical drives in my home.)
I think some streaming services allow users to download songs for playback when they don’t have an internet connection. I’m guessing, based on @Alannn ’s comment, that these local copies are DRM’d in some way that prevents playback of any copies you might make.
I’m just surmising though. I could be mistaken or else misunderstanding what he was trying to say.
I feel I would be hard pressed to find something that has all the performance and tech of the Anthem STR integrated I have, and would likely keep that and build a system from there.
As others have suggested, I would keep a hard drive containing files, since this would be less easy to replace than audio components.
"Abby someone..."
I'm going off topic, but you posted a photo from, for my opinion, one of the greatest cinematic masterpieces!;) ;)
I’m vacillating now between my Reference 1 Meta’s, and my fairly new to me Trinnov Nova. As I think about it, the Nova is the one component that I’m quite sure I would replace. I love the speakers too, but I could imagine trying something else just for the enjoyment of the journey.
Hey, Hey, @MattHooper,
Great post!
How 'bout doing a similar post on:
"You Can Trash One Component that is the Best Doorstop you Own: What would it be?"
I'd gladly nominate our KEF LSX-IIs for that dumpster! :mad:
It is very hard, or almost impossible, for me to choose "one component" or "one device" from my almost completed/established total audio setup (ref. #931 and #1,009 on my project thread).
Nevertheless, since you said "It’s a thought experiment" as well as "If your system was going to be taken away, but you got to keep one single component, from which you can move on and rebuild your system with different components, which component would you keep?", then I would like to keep the pair of YAMAHA JA-0801 vapor deposited Beryllium 8.8 cm midrange dome driver (still the best world-heritage midrange driver, I believe) for sure!:D
Great post!
There's a Dynaco 400 in the basement. I've never had the nerve to do anything with it. It is pretty beefy and would hold most any door open -- or closed.
Simple... I'd sell everything and anything I am not currently using. I am not sure if I'll ever change anything about my equipment going forward. Maybe just driven by app obsolescence or stuff dying (hopefully not me yet ).
