York DSP devices
Only negative for me is if I understand correctly, the first gen DSP board will not work with the latest software.
The reason why your order is not shipped is exactly that - I'll include a small adapter board with USB->1st gen 2x4.
Sorry about the delay, need a bit of a custom firmware for this case.
I agree Sigmastudio should remain the "advanced mode" don't waste time reinventing the wheel.
The UI you code as a "beginner's overlay" should remain basic, put your dev time into accelerating the release of better / cheaper hardware releases.
I personally do not want DSP "hard coded" integrated with the power amp stage, if I have to pay for that just to use line-out so be it, but separate amp modules are much more attractive, optimised for flexibility.
Integration with BNC Word Clocking would REALLY be a plus to enable phase alignment of multiple boards, up to 32ch if not 64...
I would happily support the development of the new pcb iteration with Word Clock.
Dear Santa,
As Christmas is coming, i wish for an ADAT implementation (in+out) on York DSP (a hat?). That would increase the number of digital channels (& possibly reduce the need of daisy chaining by spdif).
I am aware that this is a leap (*lattice iCE40HX4K), just thinking out loud. The more I read the further it gets.
The York software is really great and intutitve to use. I haven't set up the DSP amplifier just yet, but the functionality of the software looks amazing. I particularly like the ability to apply DSP to the SPDIF output as well as the input, and the ability for USB audio as well as analogue.
@eclipsevl I received my new DSP board and the small adapter board today. I did something stupid and removed the USB adapter from the Gen 2 DSP board without looking to see which pin is pin 1. I assumed the red stripe on the cable is for pin 1. I looked at the York DSP data sheet to see the pin out on Figure 6 to identify pin 1 and connected the ribbon cable with the red stripe on pin 1.
I am not able to get my MacBook (M5 chip) to recognize and connect to the DSP board. I have tried several different USB C cables but no joy. I am powering the DSP board with a 12 volt battery. The blue LED is on when I connect 12V power.
I have not been able to get the old version of York DSP board to connect either using the small adapter board. i assumed that the square solder pad indicated pin 1 on the adapter board and plugged it into the DSP board. That will not connect to my MacBook either.
I am using the latest version of York Studio. I have tried rebooting my machine. That did not help. I am assuming I did something wrong because it is unlikely that both boards are bad. Do you have any advice on what to try next? I am thinking I will try to get them to connect to Sigma Studio using the York USB interface. If that fails, i am guessing I did something that damaged both boards.
I think this is something I may consider, but I do not have any ADAT sources. Maybe next year :)
Please send me pics of the connections via DM or e-mail. I hope nothing bad happened :)
Thank you! I was thinking that S/PDIF outp can be used for subwoofer.
Also trying to extend features to auto correction: auto Xover and auto-peq:
Before:
After:
This time is for "1 Way" system and I am waiting for UMIC-1 to arrive for proper measurements.
My measurements are complete mess but the correction seems to work :)
Oh, good point. I have another XMOS board that can be a source as well.
Thanks @eclipsevl for the support that helped me discover my error and get both boards working properly on both MacBook and Windows machines. I am really impressed with how quickly I was able to setup a 3 way crossover using your GUI compared to the hours I spent doing the same thing with Sigma Studio.
Before:
After:
Another question: can the 2x4 boards be used in conjunction with each other? I.e. Can I use two 2x4 boards and control both at the same time within York devices software, or do they have to be configured one by one?
For now only one by one, unfortunately. Since I got this question couple of times, I will consider this for future, but no promises at this moment.
Copy and paste one config to the other?
Yes, the configuration can be saved to a file/loaded from a file:
Today I received a sample of new version of Centure24, v3:
1. Resolved the power supply limit, now the module works fine up to 45V
2. New revision also supports PBTL connection
Everything is moving very slow with the production, unfortunately. But at least it gives enough chances to correct what goes wrong.
The 2x4 DSPs are finally available from the Elecrow store, they kitted with all cables and a small USB connector boards:
