On 2x4 DSP on the 12 pin connector it is I2C bus for control transactions, not I2S for sound.there is something still not clear to me. With new DSP board are the I2C lines routed to the 12 pin connector useful as either input or output? It sounds that way when you mention expansion but I would like to be certain
Last week I sent the prototype of DSP with 8 channel DAC (photos in post #3 of this thread) to @KoifarmI am very interested in something like the ESS9039pro 8 channel board mentioned by @Koifarm unless you have a similar product coming out soon.
Thanks. For now, I am going to experiment with using one of the low cost DSP boards from Deyin on Aliexpress. I bought one of them to learn on many months ago. Removing the CODEC board exposes all of the pins to work with I2S.Hi @Mark185
It is working but it is a prototype so couple of things need to be improved. Maybe after some feedback I'll start putting together a new PCB design for 8 channel device.
But not sure how many ADC channels, maybe make it as optional board...
I am also 63 years. Always eager to learn. I am used the first DSP( Behringer DCX2496) several decades ago. Now have DBX PA2. All with ready made user interface. But they all have some noise at my tweeters. Now I am using york pico/ es9039q2m 8 channel combo with camilladsp and no noise at all.
Yes, some things to think aboutSend some remarks to Eclipsevl, hopefully see them back in next versions.
Once I receive the parcel from PCBA fab. I hope they'll send it on Monday. There are holidays now in China, only 3 work days next week and then another week.Hi, when will the 2x4 module be available to buy? Thanks, Liam
I am guessing the York Studio software will be specific to this AKM DAC and not also compatible with the ESS 9039pro 8 channel DAC board you posted earlier. I am still learning how to work with DACs and it appears they need to be setup/controlled by software that can configure registers, filters, etc.Today is tested a concept dsp from eclipsevl. It has a York nano board, a Adua DSP and a 8 channel DAC.
Setting up windows11 and york studio was easy. In York studio I devided the 2 input channels to 2 x 4 output channels. Then I made for every channel crossovers with 24db linkwitz riley. Tested it with a sweep generator from REW. Works perfect.
Great thing is the GUI, this makes it very easy.
https://york-devices.com/index.php?page=guide&tool=studio
That is correct.York studio controls only the DSP not the DAC.
