Yggy More is Less measurements
don'ttrustauthority
Distortion on the best measuring of the two new Schiit MB dacs (based on TI chips) rises at the top end, leading the author to comment:
This is an example of why a 1khz test can often miss out important factors about the performance of a product, and further testing than just SINAD and Dynamic Range is absolutely needed.
In other words, where the distortion is may matter more than how much distortion there is.
Harmonics of 1 kHz land where our hearing is most sensitive. Harmonics of higher frequencies routinely fall outside of hearing range. So while it is good to have uniform performance -- and reason why I run wideband tests -- you can't take your eye off what matters. There is a reason why 1 kHz SINAD has had such staying power. Here is the threshold of hearing:
threni
/dev/null
