Room and boundary gain will improve bass extension, so you will have more than enough bass to cross to sub/subs. I opted for F36 over F206 due to 3x bass drivers vs 2, and higher sensitivity. Maybe I'm giving up something around crossover due to not having a dedicated mid range, I dunno. The ability to play loud and clean without a lot of power were important to me though. I also prefer the clean baffle of the F36 aesthetically. Like you, I'm drawn to the superb measurements of the F208 but they are too large for my tastes in my current room, and don't have the desire to spend $3500 at the moment.Thanks @Bear123. Wasn't able to find that one with Google. Looks smooth, though with early bass roll off.
The format looks familiar which leads me to think my 705S2 graphs came from SoundStageNetwork as well.
I'd venture to take a guess that the sound quality disparity will be bigger than what even those graphs suggest due to vastly superior off axis response. Many of the B&W's I've seen are a train wreck off axis.Side by side comparison vs. the 705S2 that it will be replacing. Both measurements from SoundStageNetwork.
dat sexy piano white cabinet contrasting against the matte black drivers, can't get the visual off my mind!
Keep in mind Soundstage! publishes a disclaimer that the NRC's chamber is anechoic down to 200Hz. So, you cannot directly accept their bass measurements, but you can use them as a relative measure against other NRC measured speakers.
As an aside, I think the BMR should be on your short list if its aesthetics appeal to you: 3 way, wide directivity, relatively flat response, low distortion, deep bass.
I did find that the BMR were the most live sounding speaker I have ever heard. It really sounds like there's a person standing in the room with you. The wide dispersion made for a really incredible sounding speaker. The soundstage was larger than life, and if found the speaker thoroughly enjoyable, I just wish the tonal balance was a bit closer to the harman curve. It pretty much butchered all the old classic rock recordings. For example, old Beatles and Rolling Stones albums are unlistenable. Again I have an untreated large room, so YMMV. All said and done, I wish I could try them again, using some room correction. Or even just adding a tilt to correct for this:
https://www.erinsaudiocorner.com/loudspeakers/philharmonic_bmr/
As an aside, I have a pair of speakers designed by Rick Craig.. and the in room response is remarkably similar. After a low Q adjustment they sound right. Something to be said for wide dispersion speakers. I get why the Salons beat the M2. I think the ultimate speaker is a 180deg wide dispersion following the harman target.
Interesting. I have been avoiding reading reviews or examining measurements until I finish testing the samples I have. (Dammit!!!) I did not know about the above "hot" PIR as measured by Erin. That overall slope does not match my results in my rooms.
I did not find them overly bright in my rooms, although I did pull down 2.3K by -1dB in my office and 2K by -3dB in my media room. I did find ideal listening position to be somewhat tricky in the vertical domain, which causes me to wonder if there is a directivity issue between the woofer and tweeter. I definitely preferred to have my ears slightly above or below the tweeter.
I had mine at ear height and it was damn near unlistenable for some recordings. I have a fairly large room with lots of bare surfaces, so this could very well be the issue. I did measure the BMR when I had them, and my response was similar to yours... Nothing like Erin's. I think my room just reflects too much energy. I have yet to use a single speaker in this room that doesn't sound irritating with at least some recordings.
They got “Piano” part right...Update: speakers came in today. (Yeah, not in the color I wanted. Dealer hiccup but will spare you the details.)
Hopefully I can post initial impressions here soon, but will let them break in for a while (my ears, that is). So far, so good though.
Congrats on the new baby! I still have the plastic on mine 7 months on... I honestly can't bring myself to unwrap them. Too precious, haha.Update: speakers came in today. (Yeah, not in the color I wanted. Dealer hiccup but will spare you the details.)
I couldn't get it off fast enough. On a practical note, how can you be sure your speaker's finish is flawless?I am also thinking of preserving the plastic as long as I can.
On the converse practical side, a demo set is probably not flawless, but with the plastic on I don’t know that yet!I couldn't get it off fast enough. On a practical note, how can you be sure your speaker's finish is flawless?
