Yaquin SD CD-3 Tube Buffer (DIY Capacitor and Wiring Upgrade)
Ahh, this reminds me of my audiophile days. :) I did countless capacitor and wire tweaks and thought the results were amazing, like night-and-day obvious. Funny thing though: The amazingness seemed to fade in a matter of weeks or months as the device "burned in". But my sonic comparisons were performed with no real scientific rigor: Hours or days separated my Before and After listening evaluations (ideally switching between the two ought to be instantaneous), and it never occurred to me that playback levels should be kept precisely the same throughout, because even a minor level mismatch will tend to favor the thing which is louder.
As for tubes, perhaps there are measurable differences in noise, distortion, and lifespan between brands, but for my last tube amplifier build, I tried the stock Shuguang 6P1s and Beijing 6N2s, and results seemed pretty good, so I didn't venture further. As with Soviet tubes, Chinese tubes are sometimes available in different grades, based on ruggedness or expected life, though I haven't attempted to verify performance claims. Small signal tubes being used as a buffer will probably last a really long time.
I can feel that. As a audio mixing/mastering semiprofessional I learned quickly the habituation effect of our brain adapting to audiochanges and making audible differences disappear the longer you listen. As for stock tubes Im also surprised how good they've gotten.
Finally, the elephant dancing around the room is sighted listening. That has been proven over and over to be problematic. There are correct ways to do listening tests that aren't simply serving the purpose of marketing:
If you did not measure yet then the pre-modification status cannot be seen. Therefore the post mod status is nice but does not show the change.
I'm aware of that. I measure the signal loop without anything in it first for reference. Then I will put the stock tube buffer in. Then I add the new capacitors. New tubes. And maybe a measurement with and without powerfilters.
If a mixing/mastering semiprofessional would not know this something would not be quite right I think. Its the basis to properly judge the mix.
