Yaquin SD CD-3 Tube Buffer (DIY Capacitor and Wiring Upgrade)
hifidude
Hi there,
this is my first post in this forum so be gentle.
I wanted to share my latest project. To my system: I run a proper chipbased discrete dac interface into two active genelec 8030c speakers + subs. This sounded great for a while and upgrading to silverplated cables and adding electrical filters for all devices there was a solid improvement but I was still missing some organic analog warmth and more holographic sound. So I decided that tubes need to enter my hifi-chain. I checked out some DIY mods and it was claimed that the 230€ Yaquin Tube Buffer with some upgrades could deliver tube sound that usually is only achived by devices in the 5k€ and up range. So I started this project in pursiut of the never ending quest of achiving the most pleasing sound possible to my perception.
The stock unit already sounds great. Maybe taking away a bit of detail that the Genelecs so precisely deliver but therefore creating a much warmer analog-like realistic holographic stereo sound with great tonal balance. But lets find out whats possible with some upgrades!
Opening the stock device:
Many already pointed out that the capacitors in the signalpath might have as much effect on the sound as the tubes have. Thats why I desoldered the cheap 4x 0,47 stock capacitors and added highend german hifi capacitors 2x 1F Mundorf MCap Supreme SIlverGold Oil (90€ each) for the output side. For the input side I replaced the 2x0,22 stock ones with 2x 0,22 Mundorf MCap Supreme Aluminium capacitors. Additionally I replaced all stock audiowire with Mundorf Angelique 0,7mm Copper-Silver-Gold wire to further enhance the sound.
Picture of new capacitors installed + new wirng in progress:
After two hours of listening I can tell there is a huge difference in the sound compared to the stock unit. The new capacitors make the sound extremely wide, spatial and dynamic. I had to adjust the angle of my speakers because now its really a huge layered soundstage. Thats exactly what I wanted. It could be a bit less wide spread sometimes. The details and dynamics are also incredible and worlds apart from the stock sound but also a bit too much forward for my taste. With all the change in sound it also lost a bit of its great tonal balance and midrange presence while getting bright and a bit hollow in the mids and lows so that I had to EQ it in Audirvana and increase the volume of the subs. Still missing the tonality and timbe there was before. I hope the burn-in will do some magic. its just a bit too fast and bright. The difference to stock sound is so big, its a completely different sound and overall a great improvement. I might also have to adapt my own listening a bit more to it.
I can highly recommend this tube buffer for its audible benefits and with upgrades and some tweaks it can help to create a huge high-end holographic and resolving soundscape with more analog signature while some additional experimentation might be needed to achive the desired tonality.
Next upgrade are the tubes. The stock tubes are decent but I decided to upgrade to PSVain Art series tubes. Will update if someone is interested.
P.S.: And as there might be some that would argue that the cleanest signal is without the tube buffer and while that might be true, the analog transformation of the audiosignal by such a device can have percived benefits for alot of people. There is a scientific study about people listening music with tubes on and off and describing the effect as relaxing and more pleasant. It might be a question of individual taste.
This is a very objective forum. Generally, claims of hearing unmeasurable qualities are viewed with skepticism here. But enjoy...
Not to worry, replacing caps is OK. I doubt that there is a real improvement in sound quality or if it really was then the old caps may be not good anymore. This could all be measured.
Last I checked, DIY Audio has a place for stuff like that.
Ahh, this reminds me of my audiophile days. :) I did countless capacitor and wire tweaks and thought the results were amazing, like night-and-day obvious. Funny thing though: The amazingness seemed to fade in a matter of weeks or months as the device "burned in". But my sonic comparisons were performed with no real scientific rigor: Hours or days separated my Before and After listening evaluations (ideally switching between the two ought to be instantaneous), and it never occurred to me that playback levels should be kept precisely the same throughout, because even a minor level mismatch will tend to favor the thing which is louder.
As for tubes, perhaps there are measurable differences in noise, distortion, and lifespan between brands, but for my last tube amplifier build, I tried the stock Shuguang 6P1s and Beijing 6N2s, and results seemed pretty good, so I didn't venture further. As with Soviet tubes, Chinese tubes are sometimes available in different grades, based on ruggedness or expected life, though I haven't attempted to verify performance claims. Small signal tubes being used as a buffer will probably last a really long time.
Silverplated wire, tube rolling, mains filters?
Why not buy some tinfoil hats (correctly earthed to protect against ectoplasm) ?
Better still, just send spare cash to me, and I'll rubber stamp whatever you need to sound good when playing that 1998 Best of Abba CD. I have special audiophile holy water available.
yeah seems pretty audioesoteric first. I was also not expecting this. I come from a science background and I can tell there clearly have to be measurable sonic differences. Its all just fantasy until you try it for yourself or see the measurements. Its no mystery that silver cables can enhance detail and highfrequency audio information compared to copper cables and I had to remove the Mundorf silver wiring in the tube buffer and put the copper one back, that fixed my problem with the overly bright sound. I mean just go aliexpress and get a proper silverplated cable and compare for your self, they are really cheap nowadays and there is a sonic difference if your soundsystem is high resolving. For the powerfilters I always disregarded such stuff because I thought I dont need it because the power should be clean where I live so I didnt want to waist my money on unnessesary hifi-stuff until I replaced a broken normal 12v powersupply of my DAC with a cheap 12v Hifi LPS from Aliexpress as recommended by some users. The noisefloor went down, imaging got alot better so thats when I started to also filter the other hifi components. But this is all not mystery, users of precision equipment and electronicsmanufacturers use powerfilters for best operation and better results during laboratory testing sitations. There are devices to test and see the EMI value on the powerline and the reduced EMI value after adding a powerfilter. All High-End DAC manufacturers put special effort in low noise power transformation and power filtering by using special transformers and other components. I studied physics a while ago, there is no mystery in different components and materials in the signalchain having a minor signal shaping effect on audio and these small differences add up and do become noticable.
I could feed some signal through the tube buffer and record it, using my Antelope Audio Discrete Interface that should deliver some accurate results. I could change some components and have measurable results. Is there a program that can send white noise out to the tube buffer and can analyce the returning signal to measure frequencyresponse and imaging? Would be interesting to see.
P.S. I did try to join diy-audio but somehow hours after registering I received a mail that my account was banned without reason so that was strange.
That's just the point. No one so far has shown measurements. Just a lot of sighted listening tests.
Which measurments? Can you show pre and post?
I'm afraid that makes no sense. Technical sorts are as easily fooled by sighted listening as non-technical. This place is packed with engineers, so you'll have to prove your assumptions.
Yes I try to do that. What is the proper way? What signal should I send through and is there a way to measure it? I think I will have to a bit of research for a proper way of measuring. But I will share my results. If there are none then I would be highly surprised.
First I'd see if the frequency response has changed. It's common that crossover parts are swapped without proper attention to part tolerances. Budging the crossover point is audible, even with surprisingly small changes.
For things like tube buffers, we have already seen here in detail that many distort. If you like that, well great. But I think most here agree that tubes have become a fetish. Once upon a time tube amps were good quality with inaudible distortion. It's annoying that people think there was some tube sound. That only happened when they were broken.
If you did not measure yet then the pre-modification status cannot be seen. Therefore the post mod status is nice but does not show the change.
That is true.
Also, if the claim is that coupling capacitors are causing some improvement, you'll need to measure distortion before and after.
Reactions: SSS
