Yamaha YH-5000SE Flagship Headphone Review
Rate this headphone:
    Votes: 228 93.1%
    Votes: 14 5.7%
    Votes: 0 0.0%
    Votes: 3 1.2%
This is a review, listening tests, EQ and detailed measurements of the Yamaha flagship YH-5000SE open back headphone. It was kindly drop shipped by a member and costs US $5,000.
Unlike many high-end headphone, the YH-5000SE is quite light. It is sturdy though as parts are made out of metal. I really like the adjustable suspension band as once to your liking, it almost feels like you are not wearing a headphone! Very nicely done on this front.
The drivers are mounted quite deep in the cup with a very transparent fabric protecting them. It doesn't show well in this picture but here it is anyway:
Two sets of pads are provided. I opted to measure with the default leather ones you see here. There is another set that is made out of velour. It is similar thickness and compresses very easily.
If you are not familiar with my headphone reviews, please watch this video on how I measure headphones:
Fitment on the fixture was very easy although in higher frequencies, slightest adjustment would change the dips in response.
Yamaha YH-5000SE Headphone Measurements
Let's start with our usual headphone frequency response measurement using industry standard GRAS 45CA fixture:
Yamaha Flagship High-end Headphone YH-5000SE Frequency response Measurement.png
I could not believe this response at first thinking something is wrong in my setup. But another reviewer measured almost exactly the same. I don't know what would justify that peak between 1 and 1.5 kHz. What follows it depressed jagged response from 2 to 5 kHz is another major oddity. We may have some clues here when we look at the distortion measurements but let's look at relative frequency response:
Yamaha Flagship High-end Headphone YH-5000SE relative Frequency response Measurement.png
EQ development by hand/eye will be difficult but wait on that verdict. Here are the relative distortion measurements:
Yamaha Flagship High-end Headphone YH-5000SE relative THD Distortion Measurement.png
We didn't need more bad news but Yamaha delivers it to us nevertheless. As soon as the 114 dBSPL sweep started, I could hear severe distortion through the rear of the cups so didn't even need to look at the graph to see that problem. But even at 94 dBSPL we have narrow peaks between 2 and 3 kHz indicating resonances. Given the need for equalization, YH-5000SE doesn't leave us in a comfortable position. We could write off the headphone at this point and be fully justified but do stay tuned until end of the review.
Here is absolute distortion response:
Group delay is very messy indicating multiple sources mixing which points to more points of resonance:
Notice how the pattern from 2 to 3 kHz matches the distortion spikes.
Even our impedance measurement shows signs of this:
Sensitivity is about average:
Yamaha YH-5000SE Listening Tests and Equalization
It is warmer in my lab so my music listening is done with Tanchin One IEM. As soon as I swapped that for the Yamaha, the sound folded in and lost any spatial cues, as low as they tend to be with IEMs! I was not hopeful I could properly EQ the headphone but my quick attempts with some fine tuning produced excellent results:
First the negative: this headphone can't produce sub-bass with or without that bass filter. It simply gets distorted. Distortion there is a real problem. Fortunately most music doesn't have such spectrum and on rest of my music library, listening at modestly loud levels, I could not detect that distortion.
With the filters in place, the vocals came forward now as they should have been. Spatial qualities massively improved with sound now extending quite wide on each side of my ears (in relative terms). Now, combine this with a very lightweight and comfortable headphone that the YH-5000SE, and you could understand why I just laid back past midnight, and just listened to track after track and enjoying every bit of it!
Objectively, the YH-5000SE is very flawed both in tonality and in transparency (distortion). I don't buy it for a moment that much of this is intentional/voicing. You would need very elaborate equalization circuits to create that chewed up frequency response. And that leaves you nowhere in explaining the distortion even though at least one reviewer tried, calling it tube like. No, not remotely so. These are design mistakes that should have been caught and remedied. Build a proper headphone first and then change the tonality if you like, and document it.
Subjectively, the headphone sounds as bad as it measures. It destroyed my reference tracks of all genres. Female vocals collapse to the back of my head. Orchestral music sounded dull lacking resolution and spaciousness. I would say the overall fidelity was if you mixed AM and FM radio together for those of you who remember those things! :) No way any Yamaha Piano sounds like this in person. Listening to recording of such through this headphone would destroy the art, not recreate it.
Shockingly, four filters transformed the sound to a magical place I didn't think was possible given what we had to work with. Then, back up forces in the form of comfort came in, producing a very enjoyable and satisfying experience. It hugely softened the blow of the objective measurements in the eyes of this reviewer. This shows the power of building correction filters based on objective measurements, salvaging what at first would not have seemed worth the effort.
If you are listening to this headphone and think this is what music is supposed to sound like, I highly recommend you get the aforementioned Tanchin One IEM to appreciate what high fidelity music reproduction is all about. At $27, it is pocket change. Indeed, I am listening to that IEM and marveling every second at its fidelity but we digress.
I can't recommend the Yamaha YH-5000SE although I do wonder if would be happy using it everyday with EQ and appreciate its comfort.
This is the video video I references in the review. It is in Korean but with nicely done English subtitles. It shows the headphone better and you can see his measurements correlating with mine:
This person accurately describes the experience to provide support for the idea that sighted subjective opinions aren’t worthless
The response of this headphone is so deviated that subjective experience is going to be more correct than not.
Yamaha is one of the few companies from which I wouldn't expect such an overpriced mess, thank you for reviewing it and the brave buyer that bought it and even sent it for testing!
Holy moly!
Looks like a dynamic driver bass got together with a peaky estat midrange and an old school planar treble valley.
I absolutely adore the design and it looks exceptionally comfortable…but no thanks. What a mess.
Thank you for the review Amir.
Given the typical competence of Yamaha's engineers, these results are shocking and embarrassing. If this was $100, you might be able to argue that the decent sound when EQ'd coupled with good comfort and build quality was worth it.
They cost 50x that much.
I guess that is true. Sort of like a horoscope I suppose.
I tried this on once in a store and had to take them off after a few seconds because it sounded like they were broken. Looks like I'm not wrong!
No guess could do justice of this mess.
I'm sentimentally attached to Yamaha but that mess has no excuse.
And it's a pity cause they look beautiful and along with comfort could be a big deal!
Pff...
Thanks Amir!
Looks like the LCD X's evil twin--especially the FR! Costs about five times as much, and unlike the 2021 version of the Audeze, this thing is not really EQ-able. At least not so as to be able to perform to expectations even if it's comfortable and can be made to sound fairly good. So no soup for you, Yamaha!
Thanks for the review, Amir.
For reference, here is measurement of one of the original Yamaha orthodynamic designs that this YH-5000SE is supposed to be inspired by, released way back in 1976.
They really do sound great for the time period, and it's one of the reasons YH-5000SE generated some buzz during its announcement.
This makes it sound like it’s reproducing the sound of the vintage headphone? Hard to know.
This person accurately describes the experience to provide support for the idea that sighted subjective opinions aren’t worthless - they are just at higher risk for bias.
They're genuinely one of the worst things I've heard or in the top few. My Yamaha HP-3 from the 70's sound many orders of magnitude better and they cost £60
What a huge let-down. How could a crazy-money product from a quality brand be so bad? Did the real engineers take a break while the lunatics were let loose?
