My overall take on this product. If you were limiting yourself to two channels only (like this product does), then wouldn't it instead make more sense to buy active speakers, a miniDSP and a seperate DAC, which you'd combine with REW to perform your room EQ....at which point you'd end up with even greater room EQ flexibility as well as massively improved sound quality (as seen by the large increase in noise when room EQ mode is activated on this Yamaha unit). I think the cost of the miniDSP and seperate DAC would be cheaper than the cost of this Yamaha unit whilst gaining increased roomEQ abilities and also improved sound quality. (I guess you might miss out on some input connectivity options, but I've not looked at that in detail.)
What you guys think, am I right about this, or have I overlooked some stuff? I think the only argument for this Yamaha product is if you've already got passive speakers you're happy with, rather than someone setting out to build a whole new 2-channel system.
It really depends on your source.
If you mainly listen to CDs and have a player with a digital out, then the miniDSP could be good.
But it doesn't make sense to me to invest in separate DAW
and miniDSP...then what is your source? You've got a round trip on AD-DA on the MiniDSP, which isn't all that great. If your source is a computer, then all you need is a decent USB DAC, and you can run an EQ in software that will be more flexible.
Many laptops have built in digital outs, in which case you can just run right into an amp like the Yamaha if you want to use the DSP.
If you have multiple sources, let's say you run your tablet, CD player, DVD, phono, there's no good way to integrate a miniDSP into a receiver.
I'm not much of an 'audiophile' (though am very picky in my own way.) I listen mostly to Spotify 320kbit and reuse the misc old iphones we have about as players. I can leave them hooked up to my various home systems, and run them all via Spotify connect. It's like a poor-mans multi-room system with wireless control. Spotify does have a five band EQ build in, which works for broad tuning (running on local phone). So if I have speakers that need extra bass or whatnot, I just have it set for the system.
I rarely listen loud, so the quality of the speakers dwarfs all other concerns.
