thanossapiens
- Joined
- Feb 8, 2021
- Messages
- 49
- Likes
- 13
Hi, I'm really struggling to figure out something so I thought I should ask here.
A tweeter in my NS-1000 stopped working. I'm pretty sure it's the crossover because I soldiered it in the other speaker and it was working there. It's also probably not the L-pad because I connected it to the cables that connect to that too, with the same result; the tweeter works in one speaker and not in the other.
I don't know how to test each part of the crossover to find out which one is faulty but from what I understand there are just 3 capacitors that connect to the tweeter so I could just change all of them and be done with it? The problem is that I don't really understand schematics and have basically no idea what I am looking at when I NS-1000's. Can someone tell my what specs the capacitors need to be and which ones in the crossover I have to change them with?
Thanks
Thanks
